brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Hey fellas,
I have a set of pedrinni wheels I'm selling. THIS is NOT a classified. Someone has asked me whether they are early or late wheels? I know it has something to do with hubcentric rings, but can someone help me remember... Is it the early or late wheels that do or do not have the hubcentric rings? thanks in advance brant |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I believe the late wheels did not have the rings.
Check Rusty's(Lawerence) web site for more info |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Late Pedrini's are milled for the hubcentric hubs. Early wheels will not fit on a later car, without some machine work.
-Rusty (IMG:style_emoticons/default/smoke.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Rats, didn't I reply to this already? Or was that on the PP 914 BBS? Hmm, I get lost so easily. (IMG:style_emoticons/default/wink.gif)
First thing--check the part number. The ones that end in ".00" will not fit correctly on 73+ front hubs specifically. Some 72s as well, I think. The ones that end in ".01" will fit fine on any 914-4 hubs. OK, this is a Fuchs wheel without the center machined for the hub-centering ring. (Note the different casting than the standard Fuchs! Don't know if the Pedrini has similar casting differences or not.) Attached image(s) ![]() |
Dave_Darling |
This is a standard Fuchs. Note the machining in the middle, as well as the different casting.
Dave_Darling |
In this pic, we see that someone tried to modify the early wheel to fit the later hub.
Lo-Fi Version | Time is now: 30th June 2024 - 09:16 AM |
