Trevorg7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region ![]() |
I was replacing a fuel filter this weekend when I cracked a fuel line.
It got me thinking that a Car-b-q would not be good. Any suggestions on mounting locations. Pictures? thanks T |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Where you can get to it the fastest and easiest..............period
Mine resides behind the driver's seat. |
Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
Mine is mounted on top of the tunnel, just to the right of the shifter. Should be easy to reach with one hand.
Elliot |
Trevorg7 |
I am assuming that with shallow sheet metal screws I can mount it to the top or passenger side of the center tunnel (I do not have a center consol)?
T |
r_towle |
Best place I have seen is on the floor in front of the passenger seat...
Easy to reach, out of the way for the most part. Rich |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
front trunk. sorry but the last thing i wanta do is try to reach over and get something of the wrong side of the car when its on fire, just pop the front truck on the way out and then hose the ground under the car and call the insurance co. and say i tried to put it out .(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) now where's my check hagerty?
Elliot_Cannon |
That's what I used. Elliot |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
I put mine down near the e-brake handle on the driver's side. Nice & close!
Racing916 |
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States ![]() |
Here is where I mounted mine, It is out of the way, and easy to get to if needed, be sure to mount metal bracket to metal floor if you are going to do DE with your car.
Steve Attached image(s) ![]() |
jgara962 |
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California ![]() |
I've been meaning to get one myself for the same reason. Do you guys use halon, or just the standard ABC chemicle extinguisher?
messix |
halon works best where it can be contained. not sure if the 914 engine compartment the way that it is split upper and lower would work well. the halon would have a hard time staying in the top vented upper part.
Racing916 |
ABC is mine, good for everything
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
I had a Halon in my car way back.
Don't have one in the car right now (or an engine for that matter...). There are pros and cons to both. The Halon, and other similar types work by displacing the oxygen, thus extinguishing. They work great in enclosed spaces. In the open however, they don't work well at all, as even the slightest breeze can move the displacing gas away amd the fire can re-ignite. A nice thing about Halon (and similar) extinguishers is that they're clean. No residue, no mess. The dry chemical extinguishers are great to cover and kill a fire that is exposed to the outside environment. The dry chem coats and will cover the fuel source and kill the fire. Downside? It makes a royal mess. And should be cleaned up quickly as it can corrode aluminum. But if you're in the car and need to pull that pin, a little aluminum corrosion is probably the LEAST of your worries... Another downside of the Halon is if you pull the pin while you're in the car, DON'T BREATHE. Bad things can happen to those that breath in Halon... Halon is harder to get and more expensive too... -Josh2 |
jgara962 |
I was worried about corrosion with the dry chem, but the halon extinguishers seemed a little pricey. You've answered my question. Better to make a big mess than to watch your pride and joy burn to the ground. Going to buy one tonight after work. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) That's where mine is. |
SLITS |
I thought there were two types of Halon for fire bottle systems...one really bad and the other not so bad. |
jgara962 |
Just a quick question - if I mount it on the side of the tunnel, I'm not going to screw into a fuel line or anything will I? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
kdfoust |
Senior Member ![]() ![]() ![]() Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California ![]() |
Driver's side long just in front of hand brake.
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) John |
Flat VW |
I worked on a hospital job where two fellas rode out a halon dump in the MRI area. John (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) P.S. Both still alive...., one of them never acted quite right even BEFORE the halon. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:27 AM |
