jnp914 |
Member ![]() ![]() Group: Members Posts: 177 Joined: 19-August 03 From: Las Vegas, NV Member No.: 1,046 ![]() |
For a dedicated track car, is there a real difference between Weltmiester rear springs and Eibach? I am thinking 140 lb springs on Bilstein sport shocks.
Sway bars to be decided later, or should that determination be made in conjunction with the springs/shocks? |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
If I had my choice, I would choose Eibach, but I have no scientific evidence to support that decision.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
weltmeister 140's are what i drive on the street.... i think you would want stiffer springs for a dedicated track car...just mah .02
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Eibach's all the way. Weltmeister's, with the exception of the 140# springs are progressive. I have found that to cause handling to be different, depending on the corner. Lower speed aharp turns caused me to understeer like a snow plow. I have found "suspension heaven" with 22mm torsion bars, 22mm Tarett sway bar, 200# rear springs. Next up is a set of Muellers Bearings and a set of those fancy strut mounts (IMG:style_emoticons/default/smile.gif)
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(jnp914 @ Sep 1 2003, 05:45 PM) For a dedicated track car, is there a real difference between Weltmiester rear springs and Eibach? I am thinking 140 lb springs on Bilstein sport shocks. Sway bars to be decided later, or should that determination be made in conjunction with the springs/shocks? "dedicated" in what class ? is this a PCA Stock Class Club Racer, some kind of Improved Touring class, or an all-out big-horsepower/monster slick class ? my preference would also be for Eibach but i don't have any hands-on A/B data to support it ... there's also a few valvings of Bilsteins so just knowing the name doesn't help specify much, although i agree with your choice :-) yes - the suspension is a system - springs (torsion bars), antiroll bars, dampers (shocks) and all the parts must play together (for best results). as always - Step Zero is to read the rulebook for your intended class and make sure you know what modifications are legal before beginning... |
Lo-Fi Version | Time is now: 2nd July 2024 - 09:43 AM |
