Ignition cylinder/switch removal, how? |
yarin |
Feb 13 2006, 09:54 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I've got a new tumbler and ignition switch. How do I go about getting the old one out?
r_towle |
Feb 13 2006, 10:04 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
take off steering wheel
take out the screws holding the wiper/blinker switches in. remove them...they have wires and hoses connected to them, so unplug all of that. Then you will see a screw that is holding the key tumbler and ignition switch in...remov e it. Unplug the ignition switch and pull the assembly out. If you no longer have the key...you will need to forcibly remove the key tumbler from its location with a slide hammer. there is a really small screw holding the ignition switch in place...remaove that and wiggle the switch out of the housing. replace and you removed it. Rich |
eeyore |
Feb 13 2006, 10:37 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Lo-Fi Version | Time is now: 25th June 2024 - 10:58 PM |
