biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
getting off the freeway tonight, i was making a turn, not too hard, but a red light came on, it is the red light on the top of the left gauge, it flashed a little in the turn, but turned off after i came out of it, is this something i should worry about or are these things known to come on on accident every once in a while?
thanks Attached image(s) ![]() |
Korijo |
[]D o [] o []V[] o []D ![]() ![]() ![]() Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 ![]() |
Something is up w/ your brakes. Bad MC, calipers FUBAR, etc.
That is a brake system idiot light... (IMG:style_emoticons/default/ohmy.gif) |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
chech the brake fluid level.
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Check the connection of the two connectors on the drivers side of the master cylinder.
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,448 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
I always thought it was just the emergengy brake engaged light. Does it have more than that function? Check the contact for the emergency brake, maybe it's messed up.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Two functions.
It flashes as the ebrake warning also. Make sure your handle is all the way down. There is a small pin right below the handle mounted to the frame rail running across the floorboard. B |
Lo-Fi Version | Time is now: 4th July 2024 - 01:38 PM |
