> how do you test a fuel level sender?
GaroldShaffer
post Feb 15 2006, 07:07 AM
You bought another 914?
So in my statsh of parts I found a fuel level sending unit, it looks in good shape but how do you test it out of the car?
Replies(1 - 6)
SLITS
post Feb 15 2006, 07:30 AM
"This Utah shit is HARSH!"
Hook it to a guage, supply power, move float up, watch guage go from E to F. It's a matter of variable resistance.
GaroldShaffer
post Feb 15 2006, 08:40 AM
simple enough, thanks!
914Sixer
post Feb 15 2006, 12:48 PM
The first thing to do is shake it and listen if the float slides up and down inside the tube. If you do not hear this it will not work. You can very gently remove the tube and repair the float. Then you can do the resistance test.
SLITS
post Feb 15 2006, 01:03 PM
Now Mark be careful....you know you should not shake up a Kraut...just look at Ahndie..... (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif)
lapuwali
post Feb 15 2006, 01:08 PM
Not another one!
If you have a multi-meter, measuring ohms across two of the pins should give you infinite resistance with the sender held upside down (float at the "top"), and 0 resistance with the sender held upright. This is the light switch. Two other pins will give you a variable resistance from 5-10ohms with the float at the top, and 70-90 ohms with the float at the bottom.
There's a description of which pins to what in my blog.
GaroldShaffer
post Feb 15 2006, 02:19 PM
Thanks! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
- Lo-Fi Version Time is now: 2nd April 2025 - 02:04 AM
