davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
Now available is a kit that includes ALL of the typically worn components in the 914 door stop mechanism: the aluminum door stay, the plastic roller, and the metal roller. (The metal roller was originally aluminum from the factory; you'll note that I've made it from brass. More on that below.)
A brief description of the pieces: 1. The door stay is machined from 6061-T6 aluminum plate, 3/16" thick. This alloy is stronger and harder than that of the OE door stay. 2. The plastic roller is plastic for 1 reason -- to minimize noise. I originally machined a metal replacement and I found that the metal roller was superb at passing the sound of the mechanism into the resonating door skin. The plastic roller, on the other hand, damps the creaking of the springs when the door is opened and closed. Much quieter. Believe me, you want the plastic. 3. The metal roller is machined from brass. The factory originally made this part from aluminum, apparently overlooking the galling problem that occurs when 2 aluminum parts are in loaded contact. Galling is one of the wear mechanisms of the factory part. The brass roller has similar hardness and corrosion resistance to the original aluminum and eliminates the galling problem. Price for a kit of all 3 pieces is $43.27. Pretty cheap price to save the door-dings in the wife's (husband's?) driver. I have them in stock. Paypal is the easiest method, although I'll also accept checks and money orders. Attached image(s) ![]() |
McMark |
I have these installed on my car. Dave is a great source for the entire replacement kit. Most cars need it. If your doors squeak and clunk when you open them, this kit is for you.
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
That looks great! BUT I received a nice, new door stay as a Xmas bonus gift. Would you be willing to sell only the rollers, and if so, could you provide an updated price?
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
davesprinkle |
Sure. I'll sell the rollers separately. Plastic or brass, same price: $15.26/each or 2 for $27.74. (Plus actual shipping.)
degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
I think I'll need 2 of them....I just took my car apart to put on the rotisserie and noticed they are both worn so much that the roller does'nt roll...its FLAT on 1 side.....
will you have these in a month or so?? Josh |
davesprinkle |
They're available now. Shipping should be between 2 and 5 days, typically, via USPS.
sk8kat1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 ![]() |
are these sill available?
davesprinkle |
I have hundreds. How many do you need?
sk8kat1 |
is the 43.xx including shipping ?
davesprinkle |
Sure. If you're OK with delivery by postal service, then I'll take care of shipping -- it's only about a buck or so. If you want overseas or overnight delivery, then you'll need to pay actual shipping charges. If you're interested, PM or email me and we can discuss specifics. -dave sprinkle |
Racecraft76 |
Newbie ![]() Group: Members Posts: 22 Joined: 3-October 06 From: Glasgow Member No.: 6,986 ![]() |
Hi Dave,
Fourteener from The DDK 914 forum pointed me in your direction. I need to replace my rollers and door stays, but I also need to replace springs. Do/can you supply springs also? I would need two sets of your rollers and straps and 2 sets of springs. Hope you can help. My '14's doors are flappier than a spaniels ears. (IMG:style_emoticons/default/smile.gif) Regards Stephen (Glasgow, Scotland) |
davesprinkle |
Hi Dave, Fourteener from The DDK 914 forum pointed me in your direction. I need to replace my rollers and door stays, but I also need to replace springs. Do/can you supply springs also? I would need two sets of your rollers and straps and 2 sets of springs. Hope you can help. My '14's doors are flappier than a spaniels ears. (IMG:style_emoticons/default/smile.gif) Regards Stephen (Glasgow, Scotland) Hi Stephen, thanks for the inquiry. Sorry, I don't have springs, but I've still got lots of the other pieces. (Maybe I should make some springs? Anyone want to comment about how often the springs fail?) And you should be aware that after I replaced my door stays, my 914 was STILL a dog... (IMG:style_emoticons/default/smile.gif) |
Racecraft76 |
Hi Dave, Fourteener from The DDK 914 forum pointed me in your direction. I need to replace my rollers and door stays, but I also need to replace springs. Do/can you supply springs also? I would need two sets of your rollers and straps and 2 sets of springs. Hope you can help. My '14's doors are flappier than a spaniels ears. (IMG:style_emoticons/default/smile.gif) Regards Stephen (Glasgow, Scotland) Hi Stephen, thanks for the inquiry. Sorry, I don't have springs, but I've still got lots of the other pieces. (Maybe I should make some springs? Anyone want to comment about how often the springs fail?) And you should be aware that after I replaced my door stays, my 914 was STILL a dog... (IMG:style_emoticons/default/smile.gif) Hi Dave, Any ideas where I can source relacement springs? |
davesprinkle |
Hi Dave, Any ideas where I can source relacement springs? Hi Stephen, I just inquired with a couple of spring vendors to see if they have a stock size spring that will work for this application. No luck. I'll inquire tomorrow about getting some springs custom made. I'll let you know. -dave |
moordi |
Newbie ![]() Group: Members Posts: 11 Joined: 5-September 06 From: Seattle, WA Member No.: 6,775 Region Association: Pacific Northwest ![]() |
I just inquired with a couple of spring vendors to see if they have a stock size spring that will work for this application. No luck. I'll inquire tomorrow about getting some springs custom made. I'll let you know. -dave Dave, Any word on springs yet? That's the only part I think I need. another Dave |
Lavanaut |
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest ![]() |
Are these kits still available? Need at least one, possibly two.
Thanks |
drwolf |
Newbie ![]() Group: Members Posts: 1 Joined: 7-August 09 From: australia Member No.: 10,649 Region Association: Australia and New Zealand ![]() |
do you still have the kits and if so how can i contact you to order one please?
islabob |
islabob ![]() Group: Members Posts: 20 Joined: 18-March 05 From: Merritt Island,Fl Member No.: 3,780 Region Association: South East States ![]() |
Are rollers still available ?
davesprinkle |
Are rollers still available ? Hey guys, thanks for the inquiries. I ran out of these parts and have decided not to manufacture any more. But Mikey914 at 914rubber.com makes these now. His quality is top-notch and he sells them for less than I did, lucky you. Good luck with the repair. -dave |
cconcepcion |
Member ![]() ![]() Group: Members Posts: 51 Joined: 5-January 06 From: Peoria,Az Member No.: 5,370 ![]() |
Any relation to charley sprinkle?
Lo-Fi Version | Time is now: 2nd April 2025 - 11:57 PM |
