ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
What would suit my needs for AX more?
(IMG:http://www.tarett.com/images/Products/Strut_Mount.jpg) or (IMG:http://www.tarett.com/images/Products/needle_bearing.JPG) |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
errr BOTH!!! you only go around once so go for it
Scott |
Member ![]() ![]() Group: Members Posts: 208 Joined: 13-January 03 From: Redwood City, CA Member No.: 138 ![]() |
Yep, I've got the Tarett uppers but my roller bearing bushings are by Mike Mueller ( think Mike sold Tarett the design he came up with). Everyone I have talked to says that the bushings have made the most significant improvement over any thing else they could have done. The uppers keep it that way by eliminating the camber change you can experience under heavy cornering. Something that happens with the stock rubber ones.
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
If you have stock rubber bushings or binding/stiction prone plastic bushings, the Needle Bearings will have more of an impact right off the bat. The strut mounts are considered "icing on the cake"
Tarett is my first re-seller for the Needle Bearings (front and rear) Feel free to buy from Ira, he can take credit cards, I cannot. |
ChrisReale |
Thaks for basically telling me get both guys (IMG:style_emoticons/default/laugh.gif)
I'll think on this a bit more, eventually I plan on having both (IMG:style_emoticons/default/wub.gif) |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Mike,
Are you still selling the the A-arm and trailing arm bearing kits? Or should we go to Tarett for these? Price still the same? Thanks. Mike |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Given a choice, I'd go with negative camber.
Lo-Fi Version | Time is now: 4th July 2024 - 01:27 PM |
