> Removed gas tank and...., ... look at the carnage underneath
Carlitos Way
post Mar 4 2006, 03:37 PM
I did it MY WAY
I'm assuming this is a "dealer-installed" option. Was this typical on 74's with dealer-installed sway bars?
Replies(1 - 13)
Carlitos Way
post Mar 4 2006, 03:38 PM
I did it MY WAY
sdf
Carlitos Way
I did it MY WAY
df
Joe Ricard
post Mar 4 2006, 04:07 PM
CUMONIWANNARACEU
Not dealer
But probably DAPO (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Put the tank back in and pretend you never seen it.
JB 914
post Mar 4 2006, 07:18 PM
Daddy! Finish my car NOW!!!
Clean it with a good degreaser and use metal ready on it. Spot weld in some metal and then you can use POR-15 epoxy putty to seal the seams. then apply POR-15 It's not going to be seen, so, it doesn't have to be pretty. Unless you are going for a concourse type car. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
tdgray
post Mar 4 2006, 07:35 PM
Thats' Carnage... geez you west coast boys... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
McMark
post Mar 4 2006, 07:48 PM
914 Freak!
Unfortunately you have to do something like that in order to install a sway bar on a non-sway bar car. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) It's a bit excessive, but nothing too dramatic.
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Some MetalReady, maybe a coat of some sort of paint and call it done. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Allan
post Mar 4 2006, 07:59 PM
Teenerless Weenie
(IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
Carlitos Way
post Mar 5 2006, 02:57 PM
I did it MY WAY
QUOTE (McMark @ Mar 4 2006, 05:48 PM)
So what does a "sway bar" car look like... now that I have seen a non-sway bar one?
ChrisFoley
post Mar 6 2006, 07:03 AM
I am Tangerine Racing
A sway bar car has the metal reinforcing plate with the three nuts attached (spot welded) from the outside, so no cutout on the inside.
balljoint
post Mar 6 2006, 07:05 AM
QUOTE (tdgray @ Mar 4 2006, 09:35 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
jim912928
post Mar 6 2006, 09:45 AM
personally...I'd get the reinforcement plates from engman and put in there. They are metal...triangular shaped with the bolts welded on. With the outer bracket bolted through using this it strengthen things up more then just the fenderwell sheet metal. Better yet...weld it in!
freezing14
post Mar 6 2006, 12:20 PM
freezing14
wanna see real carnage???
Root_Werks
post Mar 6 2006, 01:58 PM
Village Idiot
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 01:10 PM
