Aluminum face 914 Pressure Plates, Sound interesting to anyone? |
Dave from KEP |
Mar 9 2006, 06:20 PM
KEP Clutch Manager Group: Members Posts: 16 Joined: 9-March 06 From: Palmdale, CA Member No.: 5,695 |
Just thought I'd stop by and let you all know about a new item Kennedy Engineered Products is coming out with. I am the clutch manager here and it was brought to my attention that some of the 914 guys would like a lighter pressure plate since Sachs stopped making theirs. Ours will be out in a month or so but for now I'm only making 50. Ours will make the stock clutch 3 pounds lighter than the original and comes in 2 load ratings for now. We call them Stage 1 and Stage 2 . They have a hard Tungston/Cobalt wear surface. Anyone have any interest or thoughts?
Dave |
Aaron Cox |
Mar 9 2006, 06:24 PM
that is great that a vendor listens to its purchasers! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
what does the said setup cost? couple this to a machined/lightened flywheel for seriously light rotating mass (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
914-8 |
Mar 9 2006, 06:26 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Not on that subject, but while you are here, what do you have as far as clutch setups for high torque V8 applications?
How much? And how is it different/better than the Renegade setup? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
echocanyons |
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png) Dave,
Yes that does sound interesting. Do you need a special clutch disk or can yuo run the stock type with this? |
Dave from KEP |
Mar 9 2006, 06:28 PM
Price I suppose would be helpful. Sorry. It will have a list price of $360.
Dave |
Allan |
Mar 9 2006, 06:33 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Will this work on /6 conversions?
J P Stein |
Humm........I may need one of those. 2 minutes ago, I didn't (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Dave from KEP |
Mar 9 2006, 06:37 PM
I must be in the wrong place for replies. Sorry. Just a newbie. I'll answer this way until I learn.
This is for the standard 215mm Pressure plate. It can use any disc intended for use in a 914...Stock, 4 pad metallic, 6pad, etc. I can't speak for Renegade, but I believe their adaptions use a 228mm pressure plate. We do make those as well, but the aluminum version has not yet been birthed. Dave |
914-8 |
Mar 9 2006, 06:38 PM
Oops, left out some info.
What are your clutch options for a 914 V8 running a 915 trans? |
Dave from KEP |
Mar 9 2006, 06:41 PM
I think on the 914/6 conversion, depending on whose kit you use, you need the 228mm version. At least on the KEP conversion it is set up for the 228mm.
Dave |
nocones |
Mar 9 2006, 06:42 PM
Sportscar lunatic Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
I'm interested to know this as well, since I happen to have my V8 separated from my 915 transaxle right now. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Dave from KEP |
Mar 9 2006, 06:44 PM
We have an all aluminum version of our 225mm pressure plate which only weighs 6 lbs. It also uses the Tungston /Cobalt face. They list at $525. Dave |
Randal |
Mar 9 2006, 07:18 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Hi Dave,
I'm in. Cheers, Randal |
fiid |
Mar 9 2006, 07:26 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Don't need a different pressure plate at this time - but just a shoutout to Kep for making subaru engines bolt to 901 transmissions! Thanks!!
Dave from KEP |
Mar 9 2006, 07:30 PM
Thank you! We always try our best. We make shortened oil pans too, but I suppose you knew that. Dave |
Jake Raby |
Mar 9 2006, 08:29 PM
Engine Surgeon Group: Members Posts: 9,396 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Dave, this is what you and I talked about a few weeks back and YES WE DO NEED THEM!
I'll stock a few of them if it helps get them produced. |
rick 918-S |
Mar 10 2006, 08:39 AM
Hey nice rack! -Celette Group: Members Posts: 20,519 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What is the clamping force numbers for the stage II. ? My transaxle is currently out, and my stock parts were slipping.
Can I be more specific? What are the clampnig force numbers for the stock 1.7 compared to your new Aluminum stage II? |
Dave from KEP |
Mar 10 2006, 09:12 AM
Thanks Jake. We are only a couple weeks away, but I got concerned I don't have enough once the word got out. Dave |
Dave from KEP |
Mar 10 2006, 09:16 AM
Stock clamping force is about 1200 lbs and is good for about 180 lb/ft of torque with a stock disc. Stage 1 is 1560, good for 230 lb/ft Stage 2 is 1840, good for272 lb/ft. Dave |
rick 918-S |
Mar 10 2006, 09:31 AM
Let us know when their released. I need one. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:38 PM |
