steering wheel, diameter |
toon1 |
Mar 13 2006, 01:55 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
can anyone tell me the diameter of a stock 914 steering wheel?
914helo |
Mar 13 2006, 05:21 PM
Member Group: Members Posts: 235 Joined: 29-September 04 From: Southern Utah Member No.: 2,859 Region Association: None |
Stock wheel I believe is 15" outside diameter.
toon1 |
Mar 13 2006, 06:03 PM
thanks, I didn't think I was going to get a reply. I am getting a momo wheel today and I think I am going to have clearance problems. I have aftermarket seats that may be too high.
Just one more day in the life of a teener owner!! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
pfierb |
Mar 13 2006, 06:07 PM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
I have a MoMo Porsche Design wheel and it is smaller in diameter than my stock 73 914 leather covered .....at the moment I am to lazy to go out in the grarge and measure exactly. |
914helo |
Mar 13 2006, 08:03 PM
A lot of Momo wheels are 350mm, which is 13.8" I think. They are definately smaller than the stock wheel.
toon1 |
Mar 13 2006, 11:54 PM
I just put the wheel in. It is a MOMO protipo, bought it from LTB motorsports $130. It has the flat bottom, nice wheel. I don't seem to have to much interferance with my legs, that was a concern. I checked my seat height against another 914 with the stock seats and they are pretty close.
I am going for a drive in a minute I will let you all know how it is........ |
toon1 |
Mar 14 2006, 02:23 AM
somthing is wrong with the horn.
I have a new hub, I put the button in for the horn contact and it must have been wrong. The high/low beam went on and off and the blinkers where turning on and off. I took a guess on how it was suppossed to be. can someone explain how the horn button contact in the hub should be installed........ |
pfierb |
Mar 14 2006, 05:06 AM
Try Driving the car without having the horn button installed ....see if the signal lights cancel after making a turn...if you didn't put the hub adapter on in the exact center position i.e. centered the same as your stock wheel it will mess things up. The ground wire to your horn button must be touching metal some place it shouldn't.....Had almost the same trouble with mine. Paul F. |
toon1 |
Mar 14 2006, 10:02 AM
with the hub on, what posistion is the button supposed to be?
The PO had had the wrong hub adapter so I don't know the stock local. |
toon1 |
Mar 14 2006, 10:40 AM
I've been working on it, now the horn doesn't work at all, (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
pfierb |
Mar 14 2006, 02:33 PM
On my set-up the MoMo horn button just snaps into the steering wheel assembly it is spring loaded.....there should br a tab on the button for the ground wire.....have you got the right hub adapter? |
toon1 |
Mar 14 2006, 03:35 PM
I have the right adapter and the momo horn button and that works fine. My question is about the button that is on the back side of the adapter, the one that makes contact with the brass piece in the colum. I am looking for a stock location(rotation), i.e. 12o'clock, 3 o'clock, etc. and also how far the button should stick out the back of the hub. |
pfierb |
Mar 14 2006, 04:11 PM
Go to e-bay type in MoMo hub adapters for porsche 914 it will come up with 24Ibuy store they have a great blow up of the adapter with instructions for the installation. Hope this helps Paul F. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:36 PM |
