sk8kat1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 ![]() |
well I have sold another possesion to get more cash for the teener...
so my question is this ... if the current set up is out back: stock sways and 140# springs in front : turbo tie rods, koni yellows , and stock sways am I gonna be out of "balance " .. do I need to upgrade to the 19mm sways in the front? .....I also plan in the near future to add the koni yellows to the rear... or should I add the koni out back before it is nessisary to swap the front sways? |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
Actually that is a pretty typical set up here in Norcal. Our old classification of Bi (B improved) used 140s in the rear with/without sway, konis or bils.
Front was stock torsions with either stock or adjustable 19 or 22 sway bar. Konis or bils. works very nicely for a street driven car with some AX or Track duty. Had 2 914-4s with that set up and they drove very nicely. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Dave Bell |
Member ![]() ![]() Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None ![]() |
Stock sway and 140's is going to be tail happy... BTDT.... way too "exciting"...
Go up to 19mm sway to balance the 140's... ...or something stiffer on both ends |
Lo-Fi Version | Time is now: 25th June 2024 - 12:11 AM |
