Nice rotisserie |
Nice rotisserie |
1bad914 |
Mar 22 2006, 12:48 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
A friend built this, I like the lift cylinders, solves the how do I get the car up that high problem. He is adding a motor to turn the car. I'm trying to get a materials list ans approximate cost from him.
Attached image(s) |
1bad914 |
Full length
Attached image(s) |
michel richard |
Mar 22 2006, 12:52 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I agree cylinders are nice. Motor to turn the car over is not necessary at all, though, IMHO.
I wish mine was that nice ! |
1bad914 |
Mar 22 2006, 12:57 PM
I agree about the motor for a 914, but he is a Mopar guy doing a Cuda. It should still turn well by itself, but he is an overkill kind of guy. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
maf914 |
Mar 22 2006, 01:25 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Am I seeing this correctly or am I missing something?
Usually the mounting bars which bolt to the 914 bumper points are at the rotisserie pivot point so that the car is somewhat balanced and can be rotated. The pictures seem to show the mounting bars 1 to 2 feet below the pivot point. It is going to take a hell of a lot of effort to rotate a car shell and then hold it in place if that is correct. |
jimkelly |
Mar 22 2006, 01:36 PM
good question. |
1bad914 |
Mar 22 2006, 01:44 PM
It is adjustable, see pic.
Attached image(s) |
maf914 |
Mar 22 2006, 02:18 PM
Okay, now i get it. Thanks for the enlarged photo. With that arrangement it looks like the body may rest on the four projecting tubes which would put the center of gravity above them. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Eddie Williams |
Mar 22 2006, 04:14 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
it's ajustable to the height of the bumber of the car on the ground. It appears to then lift at the pivot, so the fulcrum length would be the distance between the pivot and the bumper bracket. This would indeen take some effort to rotate a car 1-2 feet from the pivot. I guess if I saw it in operation, it might make more sense.
Lo-Fi Version | Time is now: 26th June 2024 - 02:08 AM |
