another question, The more I learn the less I know!!! |
gopack |
Mar 24 2006, 10:53 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Are these hole needed for anything. or can I get them welded up to make the trunk water tight?
Attached image(s) |
rhodyguy |
Mar 24 2006, 11:03 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
those holes get plastic plugs. do you need some? don't bother welding them up.
k |
Allan |
Mar 24 2006, 11:05 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Normally they are plugged with plastic caps so I don't see any reason that you can't weld them shut unless you are planning on installing a front oil cooler.
Or you could ask around and see if someone has some plastics plugs laying around. I might have a few in a parts car if you want them. |
gopack |
Mar 24 2006, 11:13 AM
Just though as long as I had them welding, but yes i do need some! I have a toal of 1 (ONE).
If any one has any, or a source for them, Please contact me! THanks |
Huff |
Mar 24 2006, 11:21 AM
Newbie Group: Members Posts: 20 Joined: 30-March 05 From: Savannah, GA Member No.: 3,849 |
My first 914 had the cable break to the front trunk latch. That was really no fun trying to open the hood with a crowbar. I ended up with a crooked hood with dimples and a ruined bumper pad and seals.
I noticed looking in the Haynes that as well as access for welding, these holes allow a way to get to the cable and hood hinge. It won't be easy, but if youv'e ever had that happen, you definately want a way to get into the trunk. Leave at least a couple open and plug with rubber caps. Huff |
Allan |
Mar 24 2006, 11:22 AM
I have 8 of them you can have. With the 1 you already have that'll fill all of the holes.
Lemme know where to send them... |
dsmeyer |
Mar 24 2006, 11:30 AM
'73 914 2.0 Group: Members Posts: 134 Joined: 30-September 03 From: West Michigan Member No.: 1,210 |
There is a 5/16" hole right by the front latch to open it with a screwdriver if the cable breaks. You just have to have the bumper off to access it. |
gopack |
Mar 24 2006, 11:48 AM
Another great (non?) member, coming through for someone he doesn't know. THANKS Allan!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 28th September 2024 - 03:16 PM |
