> installing new wiring harness thru firewall, where to drill holes for passthru?
mightyohm
post Apr 2 2006, 04:28 PM
I am working on a Megasquirt conversion and I need to pass a 1" diameter harness and a smaller vacuum line into the passenger compartment to my ECU box which will sit in between the seats.
I am looking for advice on where to punch thru the firewall. I am hoping to keep the stock backpad in place with as little modification as possible.
One question I have, is where is the firewall a sandwich of 2 layers of metal, and where is it single layer? Does it roughly correspond with the crease just over 3/4 of the way down? I would like to avoid this area if possible.
My current plan is to drill a hole in the center between the seats, a few inches above the sharp ridge shown in the picture, and then run the cable down under the backpad to my ECU box. That should allow the harness to come in from the engine compartment without having to go down through the engine tin.
Comments or suggestions?
Can anyone draw a line where the sheet metal goes from 1 layer to 2 on the photo?
Replies(1 - 10)
mightyohm
post Apr 2 2006, 04:30 PM
Here is the ECU box.
mightyohm
post Apr 2 2006, 04:31 PM
contents of the box...
Megasquirt V2.2 board and a Tech Edge WBO2 controller.
mightyohm
post Apr 2 2006, 04:33 PM
AMP Mate-n-lock connectors used for the harness.
mightyohm
post Apr 3 2006, 01:36 AM
bump
jonwatts
post Apr 3 2006, 01:49 AM
no rules, just wrong
Jeff, I have a center tunnel with some of the firewall still attached. I'll take a look at it tomorrow and see if I can give you a definite answer.
yarin
post Apr 3 2006, 05:18 AM
'14-X'in FOOL
Wow... excellent work! I Really like how clean and thought out your install is. Great choice of connectors too, your connections should be 100% reliable!
The factory hole is about 1.5", but its 1/2 occupied. I managed to route my MS bundle through there, unterminated though.
crash914
post Apr 3 2006, 05:51 AM
its a mystery to me
I drilled my hole in the dented circle shown in the lower left of your picture...Yes it is two thicknesses of metal, but it works.
I also mounted the ms box to the fire wall behind the passenger seat and put the tech edge box under the passenger seat...works ok...
tdsmoonchild
post Apr 3 2006, 07:01 AM
Terry
QUOTE (jkeyzer @ Apr 2 2006, 04:33 PM)
Looks real nice!
McMark
post Apr 3 2006, 11:34 AM
914 Freak!
Double walled below the line. Single wall above. I would try to pop the lines through in the center, just above the center tunnel.
mightyohm
post Apr 3 2006, 12:56 PM
Thanks for the illustration, Mark. Looks like in order to avoid having to deal with the 2 layer section I will have to run the cables down the firewall a few inches on the inside of the cabin. Should be no problem if I modify the backpad a little bit.
- Lo-Fi Version Time is now: 26th December 2024 - 07:28 AM
