cooling fan removal |
G e o r g e |
Apr 3 2006, 08:39 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
before i drive to germany, are the 3 bolts that hold the cooling fan on 12 point 5mm? or 4mm? or were these supposed to be a differant bolt all together? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
George |
bd1308 |
Apr 3 2006, 08:46 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
different bolt...
if you dont know, try the 13mm socket. < its 13mm. b |
mcbain77 |
Apr 3 2006, 08:58 PM
Member Group: Members Posts: 155 Joined: 27-January 06 From: Houston, TX Member No.: 5,485 |
I used the 12 point (triple square) M8 size bit to remove mine. PITA. I stripped one and had to use a bolt remover to get it out. I need a replacement bolt come to think of it.
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
G e o r g e |
Apr 3 2006, 09:10 PM
never mind, put some better light (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) and found that the 8 mm 12 point was the tool.
George |
bd1308 |
Apr 3 2006, 09:12 PM
wierd....
on my 2 engines, they have the 13mm bolt. b |
mightyohm |
Apr 3 2006, 09:15 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Britt,
There are two styles of fan. One uses the bolts and the other uses the triple square. |
Lo-Fi Version | Time is now: 4th January 2025 - 06:32 PM |
