Oil Temp, Dipstick |
StratPlayer |
Sep 15 2003, 09:57 PM
StratPlayer Group: Members Posts: 3,293 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I know theres a thread out there discussing these things, I tried to dig it up to add this on too, but couldn't find the thread, but here they are, I knew the guy who makes these said he was waiting on parts to finish these.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2432918540 |
seanery |
Sep 15 2003, 10:07 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Here's the thread.
SirAndy |
Sep 15 2003, 10:52 PM
Resident German Group: Admin Posts: 41,854 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yeah, but wouldn't you want the gauge inside the car where you can SEE it when driving? what good is the oil-temp if you have to stop to check it??? (IMG:style_emoticons/default/confused24.gif)
Andy |
machina |
Sep 16 2003, 01:29 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
just a simple no hassle way to have a secondary direct reading gauge. No tubing or wires to run, I want one.
david |
Rockaria |
Sep 16 2003, 09:02 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
I just picked one up and it is aready on its way to me. For the past few months for me to to get a second accurate check on my oil temp I would stop and quickly snake a temp wire down the dipstick. This will really help me keep a no hassle track and use as a second to my oil temp "Guess o' Meter" on the dash.
I think it's brilliant. I like the idea of a mechanical oil temp solution and not just a VDO electric one. Here is the guys site: http://www.mainelycustombydesign.com |
ArtechnikA |
Sep 16 2003, 09:56 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(Rockaria @ Sep 16 2003, 07:02 AM) i can't comment on the temp sender, but i can comment on the vendor. i bought one of his billet 911 sump plates to replace the warpy pressed steel OEM plate. VERY, VERY nice part. |
1973914 |
Sep 16 2003, 10:43 AM
Member Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 |
Brilliant idea. Found out at the track this weekend that using the 30 year old wiring in the dash to run a new temp guage and sender is not a good idea. Guage read 220 - probe through dipstick hole read 179.6. Guage at 260 - 180.1 in the dipstick hole. Thremal gun at the filter showed same readings. If you are going to run guages and expect accurate results, run brand new wires from the battery as well. I nice guage like the one in this thread will help to calibrate things and keep you from wasting time and worry on innacurate temp readings (or pressure, or voltage, or EGT, etc).
Bill |
Rusty |
Sep 17 2003, 08:38 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Do you think one would be effective for a /6?
ArtechnikA |
Sep 17 2003, 09:24 AM
QUOTE(Lawrence @ Sep 17 2003, 06:38 AM) Do you think one would be effective for a /6? donno that it's long enough or flexible enough to go through the dipstick guide tube in the oil tank filler neck -- or if there's be enough clearance between the stick shaft and the edge of the meter to get it into position far enough to get the cap back on. there's gotta be a better way ... |
Lo-Fi Version | Time is now: 31st October 2024 - 06:17 PM |
