Did the 912E have Solid Discs, on the Front? |
Mike D. |
Apr 7 2006, 04:39 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,446 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I picked up a set of boge front struts with the 3.5" bolt spacing for the calipers, but they have solid rotors. No big deal because I am replacing them, as well as barings, inserts will be Konis.
Anyway, I just know what car they came off, BTW, it was all together, crossmember, a-arms, underbody swaybar... |
Eric_Shea |
Apr 7 2006, 04:46 PM
PMB Performance Group: Admin Posts: 19,288 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm guessing someone put the wrong hubs on there... should have been vented. But, I'm not actually sure.
bam914 |
Apr 7 2006, 05:01 PM
Member Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
My dads 912E has solid rotors on the front.
ArtechnikA |
Apr 7 2006, 06:45 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
901.351.401.11
sounds like a pretty old part to me. something else they were trying to use up when they built those cars ! |
Al Meredith |
Apr 7 2006, 07:22 PM
Senior Member Group: Members Posts: 967 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Is the crossmember steel or aluminum? I don't remember when they went to the Al, I think if the crossmember is steel them probably solid roters
Mueller |
Apr 7 2006, 07:36 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
steel cross members came on 911 front ends with vented rotors as well..... |
Eric_Shea |
Apr 7 2006, 07:49 PM
Wow... cool. So they used the early hubs up on the E's. Learn something new everyday. Thanks Rich. 3.5" ears... did they make a special A-Caliper w/o spacers?? I'll bet that's what they did.
Couple of things Mike... you'll need new hubs to get the vented rotors on the front and check the struts and make sure they're Boge's if you want to swap out inserts otherwise you might be stuck with Bilsteins. There's a thread that has the info to have them revalved if that's the case. |
Cap'n Krusty |
Apr 7 2006, 07:59 PM
Worldpac offers both vented and non-vented front rotors for 912Es. Must be a whatever-you-got thing. The Cap'n
Lo-Fi Version | Time is now: 21st September 2024 - 06:48 PM |
