don9146 |
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None ![]() |
Anyone else have this problem? The new starter I bought has the soleniod and field housing backwards on the mount compared to the one I took off of the car. If I mount the new starter upside-down so the field housing is away from the transmission and will fit, the wiring will not reach. If I rotate the starter the other way, the field housing interferes with the transmission. A few pics may help...
Pic 1: Note that the starters are mirror images of each other. The new starter is on the left. Attached image(s) ![]() |
don9146 |
Pic 2: With the starters turned so the field housings are pointing the same way, the wiring will not reach.
don9146 |
Pic 3: The bendix on the old starter was toast and not mating properly with the flywheel anymore.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
A couple of things you can do. Extreme = gut the new starter and put guts in old case. The wiring is easy inside the case, but I would not recommend this action for the faint of heart. The other, much easier way is to just extend the wires. An easy way to do this is to add a hot start relay. I have one and have the unit in your pic so far as I can tell (it was a tight fit with the wires) and since I have a hot start relay it helped with the majority of the wires. Your large hot from the battery may need replacement with a longer one, though because this doesn't go to the relay. Only straight to the starter as I am sure you know.
Lo-Fi Version | Time is now: 26th June 2024 - 10:55 AM |
