> Shift Fork Problem? Help
neun14
post Apr 14 2006, 09:25 PM
OK, so I just got my car (a '73 1.7) back from the local mechanic, and it feels as if I no longer have 4th and 5th gears. What I mean is that I can't physically move the shift lever to the right past 2nd and 3rd. I suspect that he did (or didn't do) something to the shift fork for 4th/5th, but I'd appreciate any thoughts on how to point him in the right direction to get it fixed. Thanks!
Replies(1 - 4)
Aaron Cox
post Apr 14 2006, 10:21 PM
Professional Lawn Dart
search "shifter adjustment"
ClayPerrine
post Apr 14 2006, 10:50 PM
Did he work on the internal bits of the tranny? Is it a sideshifter?
If so, he has the shift forks inside misadjusted.......... BTDT! The book says to put a bigger gap between the 2/3 and 4/5 selector forks. But if you do that on a 30 year old tranny, it won't shift into 4/5. You have to adjust it the same as the gap between R/1 and 2/3.
Brad Roberts
post Apr 15 2006, 12:01 AM
914 Freak!
Sounds like he has the shifter mis adjusted. Pretty easy fix if you have a 13mm socket and a racthet with a extension 3inches or longer.
Let us know if you want to adjust it yourself.
I << typically test drive everything before it rolls out.
B
neun14
post Apr 15 2006, 07:37 PM
This turned out to be an odd problem that may or may not have been affected by the mechanic pulling the shifter out of the transmission. In any case, 2nd/3rd wasn't springing back, which prevented the shifter from reaching 4th/5th. After driving it a couple of miles in 3rd, I was finally able to shift to 4th/5th. I'm hoping that this was caused by something like the lack of gear oil, rather than something like a faulty detent spring.
- Lo-Fi Version Time is now: 5th January 2025 - 12:27 AM
