Weber IDF's, How do I plug this hole? |
ematulac |
Apr 27 2006, 12:02 AM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
Looks like that lead plug was in the hole. The plug popped out and my fuel bowl was emptying out into the engine compartment.
Is there a better way to plug that hole? |
So.Cal.914 |
Apr 27 2006, 12:23 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Bummer. My own opinion having webers myself and having seen one to many 914's burned up, I would order a new plug for it. Don't mess with it, not with your fuel system. (IMG:style_emoticons/default/smoke.gif) |
Joe Ricard |
Apr 27 2006, 05:31 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
JB weld. Seriously. New plug is most likely one of those unabotanium pieces.
The plug is pressed in at the factory I doubt you can replicate it. It will leak agan anyway. The hole is a result of the boring process for one of the fuel circuits. Main gas I think. JB weld is gas resistant. Don't get it inside the hole as it WILL plug the passage and you will then be screwed. |
ematulac |
Apr 27 2006, 07:10 AM
JB weld. Seriously. New plug is most likely one of those unabotanium pieces. The plug is pressed in at the factory I doubt you can replicate it. It will leak agan anyway. The hole is a result of the boring process for one of the fuel circuits. Main gas I think. JB weld is gas resistant. Don't get it inside the hole as it WILL plug the passage and you will then be screwed. JB Weld sounds doable, and I don't even need to run to the store for it. So I should replace the plug and JB weld it to the outside of the carb? Here's a close-up of the hole. |
Joe Ricard |
Apr 27 2006, 07:13 AM
Well you need to get a little bit on the inside. JUST where the mating surfaces are. I would mix up a dab and put it on the plug then push it in. Don't put it in the hole and push the plug in because it will get the epoxy in the hole instead of around the plug.
John |
Apr 27 2006, 08:08 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Those are lead plugs.
I had to repair one at Watkins Glen about 16 years ago. Luckily, a 914 guy in the next garage over (Rocky Rookey??) had some round lead slugs used to seal up those holes. I put the round ball in the hole, set it with a punch and sealed up the outside with 2-part epoxy (don't remember if it was JB Weld or not). The other option (if you are adventurous) is to tap the holes for screw in plugs. This way, they could be removed and reinstalled without having to replace them. I would be sure to check all the remaining plugs and epoxy over them as well. When one of my plugs came out, Rocky told me to check the rest and I found another that was about to come out. |
ematulac |
Apr 27 2006, 08:33 AM
Thanks, for the help guys.
I thought about tapping those holes and using screw in plugs, too. If I can find the screw in plugs locally I may do just that. |
roundboy914 |
Apr 27 2006, 10:12 AM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
So i was up at RA last fall, running with PCA - on the warm up lap, i was smelling gas. Looked up in front of me, to see who's P.O.S. car was leaking gas. New 993, nice 944 turbo, nudder 993, all nice cars. Then i realized it was my P.O.S. leaking gas. Pull off, into my paddock space, cut off the engine. Ask a buddy to look into the engine compartment while i turn the ignition back on. The second i turn the key, he is holloring 'shut it off' 'shut it off'. Blew out the same plug that you are missing, fulel all over the place. End of the weekend, last run group, nobody around. Let's just say, after a quick trip to the local Farm'n'Fleet, a shaved down wooden dowl, and some 2 part epoxy, i was back on the road headed home.
No that's not a wick, it's a wooden dowl. Yap in a few allen plugs, and seal it of with JB Weld. |
TimT |
Apr 27 2006, 10:27 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
You can also goo some JB weld on, then insert the plug and stake it with a punch..
(IMG:style_emoticons/default/hijacked.gif) QUOTE Rocky Rookey??) I know him!! from the track and also from the business world. He and his brother run a industrial coatings company |
Lo-Fi Version | Time is now: 26th June 2024 - 04:34 AM |
