Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Mounted the pump today. Is this the right spot? I judged by pictures I've seen but I also read your pump needs to be lower than the tank (?).
Is that even the right filter to use? This is what they recommened at Napa. I put some gas in and ran the pump and there was no leaking anywhere. so just making sure, did I get everything right? Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine.
The location is OK as well. That is more or less in the factory location, which worked pretty decently. (Looks like someone got a little bit POR-15-happy!!) --DD |
Hammy |
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine. The location is OK as well. That is more or less in the factory location, which worked pretty decently. (Looks like someone got a little bit POR-15-happy!!) --DD Thanks Dave. Yes it's for carbs. Yeah I definitely went AWOL with Por-15. (IMG:style_emoticons/default/biggrin.gif) planning on making it a daily driver/rain car... (IMG:style_emoticons/default/ph34r.gif) |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine. The location is OK as well. That is more or less in the factory location, which worked pretty decently. (Looks like someone got a little bit POR-15-happy!!) --DD Thanks Dave. Yes it's for carbs. Yeah I definitely went AWOL with Por-15. (IMG:style_emoticons/default/biggrin.gif) planning on making it a daily driver/rain car... (IMG:style_emoticons/default/ph34r.gif) What kind of pump are you using there Zack? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
CB rotary?
are those "pushers" or "pullers" ? why not mount it up front ? (IMG:style_emoticons/default/smile.gif) |
Hammy |
If you have carbs, that filter is OK. If you have fuel injection, that filter is not. It is not made for high pressure and flow, and will either clog up quickly or burst. Not happy, as you can imagine. The location is OK as well. That is more or less in the factory location, which worked pretty decently. (Looks like someone got a little bit POR-15-happy!!) --DD Thanks Dave. Yes it's for carbs. Yeah I definitely went AWOL with Por-15. (IMG:style_emoticons/default/biggrin.gif) planning on making it a daily driver/rain car... (IMG:style_emoticons/default/ph34r.gif) What kind of pump are you using there Zack? No idea. Came with the car with carbs. Does it look fishy? (IMG:style_emoticons/default/confused24.gif) |
Gint |
No idea. Came with the car with carbs. Does it look fishy? (IMG:style_emoticons/default/confused24.gif) Not at all. It needs to be a low pressure pump for carbs though. No, I asked because I need to replace the POS facet pump on my carb'd 914. |
Hammy |
Oh I see (IMG:style_emoticons/default/biggrin.gif) I know there's a part number on it, I can look it up if you want.
I didn't mount it up front because I wasn't sure if I could with this type of pump. (?) I figured if there was a mistake to be made, I would make it. Also, another fuel question. What exactly is a fuel pressure regulator and what does it do? Ok, obviously it must regulate fuel pressure (IMG:style_emoticons/default/rolleyes.gif) . But can someone elaborate? There is/was one hooked up to the fuel line on my car. It looks exactly like THIS . So... what is it and is it needed for carbs? help a newb. (IMG:style_emoticons/default/smile.gif) |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Well it is a fuel reg. It is suppose to keep your preasure constant at around 3 1/2
psi. When you turn on your head lamps your pump will slow a bit, at idle it will slow a bit but when you are freeway flying it will run a little faster. so duering veriations it was designed to keep the fuel preasure constant. Yes it will be great for carbs. (IMG:style_emoticons/default/smoke.gif) |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Looks like the same CB rotary pump that I have. It has an internal regulator so you don't need another one. The nice thing about where you have it mounted is that you can use the factory pump wires & relay to power it. There is a write up in the classic section on how to jumper relay board.
(IMG:style_emoticons/default/agree.gif) You might want to run a different fuel filter. Those clear plastic ones look fragile to me. Attached image(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,114 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
a little dif appearance wise as compared to my cb. i use a stock fi filter. untimately i lowered mine a bit from the picture to ensure i was lower than the tank outlet. cb are better pushers than pullers. let gravity help from the tank to the pump. you can make a little harness that contects to the stock f.p. wiring and then use andy's method of powering the pump (it will have its own relay and fuse). it solved a fuse issue that plagued me when i was pulling keyed power from the interior fuse panel.
k Attached image(s) ![]() |
Aaron Cox |
kevin, why the inline valve?
rhodyguy |
i don't have to clamp the fuel line to change the filter. the pump inlet is lower than the tank outlet. if the valve is closed, and the car is unattended for some time, the thief will never get the car to move under it's own power.
k |
Hammy |
Hey, thanks for the replies everyone.
Do you think I'll have pump problems because of where it's attached? I only put in about a half gallon of gas in the tank to test it, and it pumped it dry... |
rhodyguy |
i think it will be ok? did your pump come with the little metal canister that looks like a filter, like mine has?
k |
Hammy |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
You'll be fine zack.
If thats an old filter. get a vw stock filter from the place on mchenry. white square thing... |
Hammy |
Andyrew |
Vw place. near the elks lodge, right by a cleaners place. down mchenry (going south) on the right.
small place. but you'll find odds and ends there. Andrew |
rhodyguy |
a pretty good oldie.
Lo-Fi Version | Time is now: 25th June 2024 - 06:38 PM |
