Ricky's 914-6/GT Calipers, Eye Candy |
Eric_Shea |
May 24 2006, 05:58 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I love 914-6/GT Calipers... just somethin about'em (IMG:style_emoticons/default/wub.gif)
Attached image(s) |
Eric_Shea |
May 24 2006, 06:00 PM
These are for Ricky Garcia and should be an awesome match for the S-Calipers up front.
Attached image(s) |
SLITS |
May 24 2006, 06:03 PM
Jeroen |
May 24 2006, 06:06 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
saweeeeeet!
Aaron Cox |
May 24 2006, 06:18 PM
so they are widened /6 calipers?
nice. i can wait for marty's spot caliper.... |
Eric_Shea |
May 24 2006, 09:04 PM
10mm wider (IMG:style_emoticons/default/wink.gif)
rickyhgarcia |
May 24 2006, 10:41 PM
UPS truck is here... Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 |
Eric,
They are beautifull....thanks for posting and the bragging rights. Your work is beyond excellent...I am now thinking sending you my front S-calipers for the same treatment. Thanks, Ricky |
rickyhgarcia |
May 27 2006, 09:50 AM
Eric,
Post #2...picture #3 Is that the adjuster cover that wasn´t holding initially?? Ricky |
davep |
May 27 2006, 09:58 AM
914 Historian Group: Benefactors Posts: 5,226 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm starting to make my own adjuster covers now. Tricky trying to get the threads into the part. Both sets of initial samples seem to work, but the third attempt should be much better.
Those outer adjusters seem to want to crack quite often. Any ideas how they can be fixed? Can't just throw them away. |
rickyhgarcia |
May 27 2006, 08:33 PM
Eric,
The following list of items you detailed in another´s member thread about putting together the 914-6 GT calipers: *10mm Caliper Spacers (included, exact match in the rear 911 m-caliper) *Longer Hardware (included, exact match in the rear 911 m-caliper) *5mm Rotor Spacer (we can supply, they're not cheap but not too bad) *Custom Pins (Michel has this sorted... for others plan on about $12-15 each at a decent machine shop) *911 Rear Pad Spring Kit *Longer Studs for the rear hubs (to accomodate the rotor spacer) I know we have done 1 and 2 on the list...and that you are currently working on on number 4. Since I already have vented 914-4 calipers in my car, number 3 and 6 are probably taken care of. What is the "911 Rear Pad Spring Kit?" Is it already there? Ricky |
Eric_Shea |
May 30 2006, 09:27 AM
QUOTE Post #2...picture #3 Is that the adjuster cover that wasn´t holding initially?? No... one of the 'inner' adjuster bores is stripped (post #2... picture #1). The one in picture #3 is an outer adjuster cover. The new 10mm cover for the rear is deeper and it makes it's way to some threads. We call that dodging a bullet. Dave, your fellow countryman Bruce N. has made the outer covers already. Might want to take that into consideration... |
Eric_Shea |
May 30 2006, 09:32 AM
QUOTE Since I already have vented 914-4 calipers in my car, number 3 and 6 are probably taken care of. What is the "911 Rear Pad Spring Kit?" Is it already there? The cores we used for the GT kit had springs so I had them plated and refurbished (riveted). You're all set there. 3 and 6 are rotor spacers and longer studs. If this is a GT clone you may want to take this time to install the 72mm Verbus studs in your hubs and use the open lug nuts. I'm not sure how far you want to go for the sake of GT appearance. Regarding the rotor spacers. I believe we decided that you were going to attempt the spacers underneath the caliper ears (which I think is what you had). If that didn't/doesn't work we have the rotor spacers to go that route. There are two ways to go about it: 1. Space the caliper 5mm off the ear moving the centerline back to align with that of the 911 rotor. 2. Space the 911 rotor out 5mm to move the centerline out to match that of the 914-6/GT caliper. This is sometimes the only option because the 914 based calipers come 'very' close to the trailing arm. |
Mrs. K |
May 30 2006, 10:24 AM
Grieve we must, but celebrate a great life! Group: Birthday Fairy Posts: 7,513 Joined: 6-June 04 From: Long Beach, CA Member No.: 2,166 |
(IMG:style_emoticons/default/idea.gif) ..........does A-aron wear them when he comes to "visit" you (IMG:style_emoticons/default/grouphug.gif) I think we all know how much you two like "toys" (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/av-943.gif) |
rickyhgarcia |
May 30 2006, 10:58 AM
Eric,
Thanks for the info... |
Lo-Fi Version | Time is now: 8th January 2025 - 12:49 AM |
