> had to give up for the day, i thought it was ready to fire
lotus_65
post May 29 2006, 07:31 PM
carbs are in, harness hooked up, power to everything,
except...
the fuel pump. it's up front and the (red) power line runs along side the main harness above the tunnel and ends in the engine bay. i just can't find any power off the relay or anything!
the pump is high the o.p. one from the fi, and there's a loop in play. it was connected to run constantly, not to shut off. the fuse is present and was working fine previously.
should i just run power to it, or does it need to go into the harness somewhere?
(IMG:style_emoticons/default/confused24.gif) thanks
Replies(1 - 2)
Dr Evil
post May 29 2006, 09:49 PM
Send me your transmission!
Did you also jumper the appropriate connectors on the cirrcuit/relay board in the engine bay?
lotus_65
post May 29 2006, 10:13 PM
QUOTE(Dr Evil @ May 29 2006, 09:49 PM) *
i didn't do the carbs.
would that be so the pump shuts down when you kill the engine? if so, that wasn't done. but it worked well cycling fuel around the loop.
otherwise, i don't think anything was rigged on the board. tx
- Lo-Fi Version Time is now: 26th December 2024 - 08:36 AM
