evan |
Little Bean ![]() ![]() Group: Members Posts: 117 Joined: 8-September 05 From: Gaithersburg, MD Member No.: 4,767 ![]() |
Okay got spark from the center wire to the distrib cap. distrib rotates when engine is cranked. acutally started when choke & carb cleaner was sprayed in carbs to clean. then it quit and backfired. help need to get the teener running before my father comes for a visit.
e |
wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
sounds like you are not getting fuel? Check into your fuel pump, relay, wiring, filter, etc)
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
What year and engine? Do you hear the fuel pump hum for a couple secs when you first turn the ignition on?
evan |
Hey Rand, when I first turn the key, i hear a humm / clicking sound. In checking the filter, should I disconnect the end opposite the filter away from fuel source?
evan What year and engine? Do you hear the fuel pump hum for a couple secs when you first turn the ignition on? |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
humm = Fuel pump
clicking = Fuel Pump relay, Ignition System Relay on the filter, i wouldnt think it would matter, but i always disconnect the fitting closest to the pump first, so teh sediment doesnt backwash into the pump. b |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Hey Rand, when I first turn the key, i hear a humm / clicking sound. In checking the filter, should I disconnect the end opposite the filter away from fuel source? evan What year and engine? Do you hear the fuel pump hum for a couple secs when you first turn the ignition on? Yes, and sence you are going to pull that off put a piece of hose on it and run that hose into a receptical and have someone turn on the key and check out the flow it doesn't take much preasure for carbs. At least you will know that it is or isn't your fuel pump. |
evan |
Hey Rand, sorry it is a 1973 and I think is a 1.7 converted or bored out to be a 2.0.
evan |
Okay, just took off one hose from the fuel filter got some drainage. tried to start car and some gas came into a cup i had underneath the filter. when i reconnected it the car almost started but did not quite make it. Do fuel filters get clogged that quickly?
Hey Rand, sorry it is a 1973 and I think is a 1.7 converted or bored out to be a 2.0. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:26 AM |
