Leaking Fuel Pump(Repairable)? |
adidas |
Jun 15 2006, 12:15 PM
Member Group: Members Posts: 489 Joined: 6-February 03 From: Charlotte NC Member No.: 250 |
Hey Guys I have a 70-74 factory 3 port fuel pump. I tested it with 12 volts and it runs. I tested for fuel flow by taking the suction and return hoses and submerging them in a container of gas and routed the discharge hose to an empty container. When power is supplied to the pump it leaks around the black plastic electrical plug that the wiring harness plugs into and is putting out no fuel from the discharge hose. Is this repairable or did I route the hoses wrong. Thanks. Bill
drgchapman |
Jun 15 2006, 12:18 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
It's done.
Get ready to spend some $$$$. Iffin' you can find one. |
sean_v8_914 |
Jun 15 2006, 12:29 PM
take it apart and fix it
dinomium |
Jun 15 2006, 01:03 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
just replace it and relocate it to the front trunk. New hi pressure pumps are around $150, you need 39psi iirc.
If you really want to stay OG, I have a three port on my shelf |
Lo-Fi Version | Time is now: 26th June 2024 - 07:42 AM |
