jsf322 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 ![]() |
I am getting a strange rattle that I cannot figure out. I hear it from the engine area when I let off the gas and coast soemtimes and when I push in the clutch to shift gears. When I shift gears, it stops the second power is reapplied. The frequency also seems to change as the engine slows so it is something vibrating in relation to the engine, but I can't figure it out. I see no lose brackets or other parts.
Toast |
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region ![]() |
Loose engine tin?
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
broken trans or engine mounts are suspect.
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
The H/E's tin will rust and the welds will give way. than it just sits and vibrates. (((((RATTLES)))))
Check it out with a rubber mallet or another appropriate tool. Let us know what you find. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
If it's coming from the nose of the engine the cam rivits or bolts are coming undone.
Check everything else first but.... BTW if you do suspect this you can tell by removing the oil pump and rocking the crank back and forth while you watch the rivets. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
jsf322 |
It appears that it is likely the outer tins on the heat exchangers. They are both loose. The right one is loose on both ends, the left one only on the back end. When I mave them I don't get the exact, but a similar sound. I will have a local shop reweld them and then see what happens. I will check the mounts when Iget a chance, but they seemed okay when I looked at them 2 days ago.
Lo-Fi Version | Time is now: 26th June 2024 - 04:44 AM |
