914 |
Senior Member ![]() ![]() Group: Members Posts: 450 Joined: 26-December 02 Member No.: 19 Region Association: Southern California ![]() ![]() |
Does the 914-6 have the serial number stamped in the trunk compartment.I just got one. The serial number is on the passenger frt wheel well/Frt trunk data plate/Drivers door jamb sticker,But in the rear trunk Floor Pan, in the center near the trunk latch area is a stamped Number 955,Its not even close to the serial number,Thanks for all the help !!!
914 |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Early cars (maybe late too?) had a chassis number stamped into the rear trunk.
it never matches the serial number. Its more of a build date chassis number. most cars have them rusted off and inlegible.. good that yours is not. I'm not certain, but assume the cardex on your car from PCA would show that your chassis and serial number are matching and thus authentic. brant |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I can certainly help in this case, and have a lot of this info in my database. First I need the VIN, then I can help you work out the rest of it.
olav |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None ![]() |
I can certainly help in this case, and have a lot of this info in my database. First I need the VIN, then I can help you work out the rest of it. I can certainly help too but with no strings attached. (IMG:style_emoticons/default/beer3.gif) |
914 |
Lo-Fi Version | Time is now: 26th June 2024 - 03:04 AM |
