Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
My partner and I have developed a dual 3.6 (964) performance chip.....one side is stock configuration...the other is performance chip that has dyno'd out to add 16+hp over and 3.6 motor output equipped with headers.......
I also have a Cyntek chip available....lemme know if anyone is interested..... |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I saw that on PP... Who's the EE between you guys?
Nice work. |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
Hi Mike,
I'd be interested in trying. I just got my car running (whoohoo! pictures to follow shortly...) and had a custom Autothority chip made that I can't get to work at all (doesn't start). Car runs and idles fine with the stock chip, but this new chip is worthless. Engine is: 1991 3.6 w/ factory Motronic Euro RS cams Andial valve springs upgraded connecting rod bolts 6.85 lbs flywheel Bursch headers, Dansk SS dual in/out muffler ((IMG:style_emoticons/default/smile.gif) -Steve |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE My partner and I have......... so, which one are you?Siegfried or Roy (IMG:style_emoticons/default/smile.gif) What are you charging for this? Is this chip "based" on the RUF chip? |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
As IF a 3.6 914 needs "more power" (IMG:style_emoticons/default/lol2.gif)
campbellcj |
QUOTE(siverson @ Oct 7 2003, 02:21 PM) What's the advantage of having is "switchable"? When do you really ever want to go slow? (IMG:style_emoticons/default/smile.gif) I suspect it's mainly a benefit in "before and after" testing as well as a potential necessity for the guys whose cars are still subject to smog nazi inspections, like Mikey's 911SC 3.6. The real zinger is when there is a service bulletin or recall that results in the dealer overlaying your custom software with the new (stock) factory code. Of course both of these scenarios are non-issues with most of our 914's and 911's. For my Audi, I have a spare stock Motronic ECU to drop in for smog inspections and also for when I used to take it in for warranty service. (Having the dealer find any software or boost mods on a warranty car is a no-no). Then I have a socketed box with two different Garret/GIAC chips; one for street gas and one for 100+ octane. At the time the switchable stuff was just coming out and was mucho expensive. |
Joe Bob |
The chip is a combo of Ruf and Cyntex with some special mods added from our experience.....any interested can contac tme direct at 356@cox.net
Or they can just buy the straight Cyntex one that I no longer need...... BTW...the other advantage of the dual chip is when you are running crappy California octane and only need stock preformance...you have the ability to do so....the performance chip will retard the system and run at less than optimum with less than 93 octane.... BTW2....Ingo has a Doctorate from some Uni in the Fatherland....we also have dyno sheets on the chips.... |
need4speed |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 ![]() |
Just curious - do you guys shoot new chips specifically for this application, or do you use an FPGA of some kind?
Lo-Fi Version | Time is now: 26th June 2024 - 04:10 AM |
