Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
I keep looking at the height of the teener since installing the 110# springs and, I swear, it looks at least 1" higher in the rear. What I can't figure out is the new springs are 3" shorter than the stock ones. I made sure the ends fit into the shock ends correctly. Anyone shed some light on this?
bruce |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
The stock ones where shot by some 4 inches... so it raised the car 1 inch. Very common for this too happen when replacing the springs.
People will call the parts place and argue that the new springs "raised" their car even tho they "bought" lowered springs. The dumbass manufacturers should remove any mention of "stock" in their paperwork. B |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Jeez Bruce, with your KYB's and new springs, you are about ready for some 914 off-road action. There is a parts car around here with Bilsteins all around. If you are interested, I could go look and see if they are still there. Might give you some ride height adjustability...??
Brad Roberts |
Junk the KYB's. Used Bilsteins will ride better than any KYB.
B |
Bruce Allert |
I kinda figured as much (I never put anything back together wrong!) (IMG:style_emoticons/default/laugh.gif) As for the off road action that is the way it looks with a slight Calif. rake.
Sure Chris, if the Blisteins are still available for not too much $$$ I'd luv to have some adjustability. Been waiting for the right time to junk the KYB's Brad, guess the right time is now. Check those out for me Chris and send me your address so I can send you the movie CD with you at AX. bruce |
Lo-Fi Version | Time is now: 26th June 2024 - 05:44 AM |
