RD Evans |
Member ![]() ![]() Group: Members Posts: 112 Joined: 20-July 03 From: Temple, TX Member No.: 923 ![]() |
Has anyone built a rotisserie using this set of plans, 914 rotisserie ? If so, how did it work out and how do you get the body jacked high enough to attach it?
Thanks... (IMG:style_emoticons/default/icon14.gif) |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I havent used those plans.. but we have built 2-3 now. I borrow 3-4 decent sized buddies and we lift the car up onto it (without suspension/engine/trans) Pretty easy actually.
Like this: This 9146 is currently at the body shop. B |
914gem |
Member ![]() ![]() Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 ![]() |
I used the plans as a guide but it looked much the same. Sold it to a guy in KC Kansas. Bid mistake selling it, I'll have to build another. To lift the car I put the car as high a I could go with jack stands and very carefully lift one end at a time with an engine hoist. Once you have it up make sure you tie the stands together before you do anything else. When I built mine I ran the beam that ties the stands together all the way through the stand. I made my lock downs behind the stands so I don't have be anywhere near under the car when I tighten down the beam that ties the stands together.
RD Evans |
I think I've the issue of getting the car on the rotesserie. I'm going to add a beam in the ceiling of the garage I building and use a chain hoist and helpers to guide the car.
tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
Rotisserie works great if you don't have to ever move it . I chose to build another form of stand.
Attached image(s) ![]() |
David_S |
Member ![]() ![]() Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region ![]() |
Here is the one that I made out of drill pipe that was laying around. Cost was about $10.00 and that was for the four casters. Chief helper is standing next to the car! I didn't know how these cars would hold up mounting the rotisserie at the bumper mounts, so I mounted mine at the front suspension mounts and transmission mounts in the rear.
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Is the kid part of the stand also? Like a tool holder (IMG:style_emoticons/default/laugh.gif)
David_S |
QUOTE(ChrisReale @ Oct 12 2003, 06:26 PM) Is the kid part of the stand also? Like a tool holder (IMG:style_emoticons/default/laugh.gif) The kid so far hasn't became part of the stand. She is also a pretty darn good tool getter. She has also scraped off more of the undercoating than I have. She is closer to being the "future owner" than her mom is! I think this car will be hers, and the 76 that is going to be redone after this one will probably belong to my son who is 7 months old now !!!! |
ChrisReale |
Send her to Seattle! I have two wheel wells with undercoating left to remove!
David_S |
QUOTE(ChrisReale @ Oct 12 2003, 09:50 PM) Send her to Seattle! I have two wheel wells with undercoating left to remove! Well, if she knew that she could go see her Uncle John and Aunt Melody that live in Woodinville, she would probably have her bags packed in a heartbeat! |
mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
I built mine after looking at several sets of plans and photos on the net.
Mine cost less than $450 to build. I used 4 6" industrial casters with brakes ($110) 2 Ag grade D rings ($12) Misc hardware ($25) 2 2-ton cum alongs ($50) The rest is cost of steel and a 12pack for my machinest buddy to bore holes. I can lift mine from sitting on the ground. I wish I had seen thoes plans for buidling my yoke. I built my yoke out of 1" sq tubing by bolting 8" peices to the bumper mount holes and then welding up the tubing to attach. Crude but effective. Photos soon. |
mr914 |
Front side
mr914 |
Back side
mr914 |
The frame. No I don't have concerns about colapse (IMG:style_emoticons/default/ohmy.gif)
mr914 |
Casters are mounted to a plate on a seperate tube. Extendable from 6" to 24"
That way if I have to transport on a trailer. I can insert a smaller square tube for mounting on the trailer.... Attached image(s) ![]() |
mr914 |
This is what I use for a counter ballance.
Crude but effective Attached image(s) ![]() |
mr914 |
Closer detail of center section
mr914 |
another view
mr914 |
View two.
I used a 7x14" plate for shimming. In final assembly, I used about .070" in shims to true up the pivots. Attached image(s) ![]() |
mr914 |
The 5/8" pins were $7 each at the hardware store or trailer supply places. (IMG:style_emoticons/default/ohmy.gif)
They were $2.25 each at the farm supply stores! Tractor supply, Wheeler's, Country General... (IMG:style_emoticons/default/beer.gif) Attached image(s) ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 11:24 PM |
