73 fuel pump, does it suck or blow? |
HeloMech |
Jul 20 2006, 07:21 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
FINALLY found the fuel filter. I don't see any arrows or anything on it. The one I bought locally shows in/out. Which side does the fuel enter the filter from? There's the short hose to what appears to be the fuel pump and then a long one that heads towards the center tunnel.
thanks |
Cap'n Krusty |
Jul 20 2006, 07:29 PM
FROM the tunnel , through the special 2 sizes hose, into the filter, then TO the pump.
The Cap'n |
HeloMech |
Jul 20 2006, 08:25 PM
well that was a huge mess for nothing. The filter I bought has the same size ports at both ends. The stock one has one large and one small. However... I learned that the stock filter is apparently clear. No debris came out and fuel moved through it FAST. The hose from the tank is old crappy stuff with a mercedes emblem on it. Needs to be replaced.
HeloMech |
Jul 20 2006, 08:29 PM
I'm confused. My car is a 73. PP shows the filter that I have 8mm/12mm for 75-76 cars. The 70-74 1.7L shows a round one with two 8mmOD connections. Grrr!!!
So.Cal.914 |
Jul 20 2006, 08:39 PM
It both sucks and blows, thats why I run carbs. (IMG:style_emoticons/default/w00t.gif)
Dave_Darling |
Jul 21 2006, 10:22 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The "little-little" filter is the stock part. It requires a special (and expensive!) "adaptor hose" between the filter and the center tunnel line. The "big-little" filter is a popular swap, because you don't need the special adaptor hose.
--DD |
Lo-Fi Version | Time is now: 26th June 2024 - 01:50 AM |
