Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
What is the best method for cleaning all of the electrical contacts??
The solderless terminals could use some cleaning as well as all of the fuse contact posts. |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I used a radiop Shak product that is an electrical terminal cleaner. A q-tip and toothpick helped also
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Worked at a computer company (in a past life) and asked this materials engineer (whose specialty was connectors) what to use. He recommended contact cleaner. In extreme cases (green connectors) he said a little rubbing with an eraser might work. (Followed by more contact cleaner)
He also recommended dipping the connectors in baby oil after treatment to keep oxygen from them. In a pinch, I have been known to use brake cleaner instead of contact cleaner and toothpaste for a mild abrasive. The absolute best fix was swapping out that ugly wiring harness for the pristine one from the parts car. I sure don't want to do that again. (IMG:style_emoticons/default/headbang.gif) So....... if corn oil is made from corn and peanut oil is made from peanuts, what is baby oil made from????? (IMG:style_emoticons/default/laugh.gif) Ken |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Diapers? If you look around electronics stores, you may find a small tub of dielectric grease, apply it to both sides of closing connectors after you clean them with Blue Shower, or sameish, and use a small brass brush (fuzzy one works best) on hard to clean ones. (brass is softer than steel... yaya) A bore brush works great, they make tiny ones, good for the deep connectors. (not a steel brush) The grease will save you from going back in there ever again, use sparingly.. Dab'l dooya, Mate! M |
Mueller |
Thanks,
at the same time, I'm going to re-do the harness to eliminate the "seat belt warning system relay with integrated buzzer" (J34) as well as do a few things with the main relay board for my Megasquirt installation. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Mueller @ Oct 15 2003, 05:04 PM) at the same time, I'm going to re-do the harness to eliminate the "seat belt warning system relay with integrated buzzer" (J34) ops, i "forgot" to hook that one up when i installed my new harness. (IMG:style_emoticons/default/wink.gif) Andy |
LS6/914 |
Never leaves the shop member ![]() ![]() Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest ![]() |
Mike, I have found that to properly disperse the green growth on the terminals (we call it "fretting" here at Cadillac) we use electrical terminal spray cleaner from your local electronics store & GM terminal coating part # 12377900 available at any GM parts location.
Lo-Fi Version | Time is now: 28th June 2024 - 11:40 PM |
