J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Speaking of 914 parts investments, I figure I can get maybe a .25 on the dollar return if I stick a set of these on the ulf.
Who was the crash test dummy for these? Any tips on the install? Most importantly, can I use a (IMG:style_emoticons/default/smash.gif) Oops, speeled his name wrong....again. |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
You mean these?? (IMG:style_emoticons/default/smile.gif)
Going out via UPS today...sorry, the 5# sledge hammer is not included, LOL Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I have installed 4 rear sets now. If you dont have a press... you need a BFH and some patience.
The hardest part is getting the 1.5 inch tube into the control arm and NOT damaging the end in the process. If you hammer on one end.. it can flare the end and make the bearing not sit in it correctly. I suggest wheel bearing grease on the outside of the tube and a piece of wood with a 3 lb sledge. The BEST/Safest way is a press. It would take someone 5 minutes per shaft to press them in for you. B |
J P Stein |
QUOTE(Brad Roberts @ Oct 20 2003, 11:00 AM) The BEST/Safest way is a press. It would take someone 5 minutes per shaft to press them in for you. B Well, shit.......I can get em' pressed in. (IMG:style_emoticons/default/sad.gif) I was looking foreward to beating the dogcrap outta' something, tho. My hands have nearly healed from the last time (IMG:style_emoticons/default/laugh.gif) |
Jeroen |
Mike,
We need to do something about your website (IMG:style_emoticons/default/biggrin.gif) Brad, When you got time to chat? (are you back from Indy yet or are you posting for Sean's computer?) cheers, Jeroen |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
we got the wireless working on his notebook, so he's been posting from his computer on my network.
Jeroen |
Ok, it can wait, there's no rush...
cheers, Jeroen ps. the pics look like you had fun |
seanery |
I had a blast once we got there (1 hour late).
Brad drove my car. And for those that don't know me too well I have control issues. I suck at being a passenger! Plus the roads look A LOT different in the teener than they did in the range rover. There seemed to be quite a bit more blind turns than I remembered. (IMG:style_emoticons/default/blink.gif) |
Mueller |
QUOTE We need to do something about your website yep, my site SUCKS !!!!! I'm 99.99% sure someone else is going to be suppling your rear bearings for you once I get around to giving them to him (IMG:style_emoticons/default/smile.gif) JP, I did the hammer (and lube) trick on my last install, but I went one step further and before installing the tube. The bearing tube is 1.50" in diameter, I measured the trailing arm and found mine to have the ID slightly oblong, so I made a die to force into the arm to help open it up a tad bit, a 1/2" drive socket of a suitable size would also do the trick. |
Jeroen |
You couldn't have been more scared than Brad when he let me test drive Scott's orange /6 (IMG:style_emoticons/default/biggrin.gif)
I had to get used to the US traffic rules (eh... that was a STOP sign, no you can't make a u-turn here), get used to the 914 shifter (hadn't driven one in over 3 years) and I was having trouble with the twilight (though I have no problems driving in the dark) cheers, Jeroen |
Jeroen |
QUOTE(Mueller @ Oct 20 2003, 09:26 PM) I'm 99.99% sure someone else is going to be suppling your rear bearings for you once I get around to giving them to him (IMG:style_emoticons/default/smile.gif) I'm getting the idea this "someone" is going to have to pay for extra lugage (IMG:style_emoticons/default/biggrin.gif) Don't worry about them though... I was just busting your ass on purpose (IMG:style_emoticons/default/happy11.gif) Just PM me some ideas you got/want/like and I'll take care of the site cheers, Jeroen |
Lo-Fi Version | Time is now: 26th June 2024 - 05:27 AM |
