URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,359 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I had been noticing my oil pressure gauge would drop to zero when under load (trailer/car and a bed full of stuff). I'd back off and it would come back up. So I took it in. They dropped the pan and found the oil pickup tube and screen full of crap. Here's a pic.
Attached image(s) ![]() |
URY914 |
Then the rod bearings were inspected. Not pretty. This is from a '99 Dodge Ram with the 318cid and 98,234 miles. Here are the bearings picture, you can see the one in the top of the picture is worn in the classic pattern.
Soooo, don't spend all your money on your 'teener-change your oil in your daily driver too. Paul Attached image(s) ![]() |
URY914 |
I consider myself very lucky (and sorta stupid for letting it happen)
Paul |
Rouser |
Anti-Post Whore ![]() ![]() ![]() Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 ![]() ![]() |
So ... what's it gonna take/cost to bring that rig back up-to-snuff?
URY914 |
$935
I don't work on trucks. Paul |
dryheat914 |
It's all good! ![]() ![]() Group: Members Posts: 57 Joined: 21-August 03 From: Surprise, Az Member No.: 1,059 ![]() |
Make sure you repair any sites of dirt entry into that engine.....Looks like you had some crap( i.e. dirt ) go through those bearings. Check your intake hoses, oil filler spout, etc. I've seen this lots of times in my cust. engines, usually from a little dirt.
p.s., don't use Fram Just my 2 cents Thanks Chris |
Lo-Fi Version | Time is now: 28th June 2024 - 08:50 PM |
