PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
I have heard that you can do this by stretching the holes. The flanges on the mount look a little wimpy to do this. Anyone done it with a big motor?
The 911 sits on top of a hole getting supported all the way around. This would only be supported by the bolts and washers. Not sure I'm comfortable with it. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
911 sport mounts are used all the time...
you are better served by weltmeister or wevo pieces |
turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
yes I even have a 911 sports mounts laying around the house. The wevo are better though.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,802 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The easiest way to make them fit is just squeeze the brackets in a little. You've only got to get a 1/4", and I just take a monster HD C clamp and pinch them together.
I've heard good things about the WEVO's, but no first hand experience. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,150 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i'm currently running the 911 sport mounts. i did *not* have to tinker with the mounting holes, but your milage may vary ...
they are holding up very well so far, i just had the engine out the other day and there was no deformation or any kind of other obvious stress symptoms on the mounts ... and yes, (IMG:style_emoticons/default/agree.gif) the WEVO mounts are certainly nicer still ... (IMG:style_emoticons/default/smile.gif) Andy |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Unless money is tight, get the WEVO mounts. They fit perfectly and the car never shifted as well.
rickyhgarcia |
UPS truck is here... ![]() ![]() Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 ![]() |
Somewhere I read the 911 engine mounts were designed for an engine resting on them...and not for a transmission hanging off of them. Based on this bit of info I thought using the 911 engine mounts was not the right choice.
Therefore, I bought a set Wevo´s from the club store...which are specifically designed for a hanging 914 transmission. |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I use 911 sport's all around and did not need to modify or feel bad about it (IMG:style_emoticons/default/wink.gif)
KT |
PRS914-6 |
Well, it sounds like everyone is having pretty good luck with the sport mounts. Thanks for the replies.
Unfortunately, I bought a roller with no original mounts to compare with. Can someone provide the thickness of the metal flange area of the OEM mount area that bolts to the car? I would like to compare it to the 911 mount thickness before I make a final decision. Off the Wevo site: NOTE; A 914 transmission mount version will be available in April 2005. The 914 hole spacing is close – but not the same as the 911 and the WEVO SS Engine Mount body should not be slotted. |
SirAndy |
Somewhere I read the 911 engine mounts were designed for an engine resting on them...and not for a transmission hanging off of them. Based on this bit of info I thought using the 911 engine mounts was not the right choice. i'm no 911 expert but doesn't the 911 engine mount bar *hang* off the mounts, just like a 914 transmission ... (IMG:style_emoticons/default/confused24.gif) Andy |
PRS914-6 |
Somewhere I read the 911 engine mounts were designed for an engine resting on them...and not for a transmission hanging off of them. Based on this bit of info I thought using the 911 engine mounts was not the right choice. i'm no 911 expert but doesn't the 911 engine mount bar *hang* off the mounts, just like a 914 transmission ... (IMG:style_emoticons/default/confused24.gif) Andy Andy, Yep, same way. The difference is like I said above, the mount sits in a hole so the mount is supported all the way around instead of hanging off 2 bolts and why I want to know the thickness of the metal.... |
SirAndy |
The difference is like I said above, the mount sits in a hole so the mount is supported all the way around instead of hanging off 2 bolts and why I want to know the thickness of the metal.... yes, i understood that part. (IMG:style_emoticons/default/biggrin.gif) i'm nowhere near my car right now and i already dropped off my box of 911 sport mounts for the RJ mount with mark, so i can't take a measurement for you right now ... i did check them mounts when we put the engine back in and they did not looked warped or deformed ... a simple solution would be to add a "brace" to the mount very much similar to what you machined for your shifter (the thing with the lip for the boot) ... just make a flat piece of metal with a flanged edge for stability and add it under the 911 mount to give it support. should be easy for you to make ... (IMG:style_emoticons/default/smile.gif) Andy |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I am using them with my V8 and 930 transmission. I haven't had any issues even hammering the throttle. I will say with my V8 I tried to use them on the engine cross-brace and they pulled right out in minutes on the road.
rickyhgarcia |
Somewhere I read the 911 engine mounts were designed for an engine resting on them...and not for a transmission hanging off of them. Based on this bit of info I thought using the 911 engine mounts was not the right choice. i'm no 911 expert but doesn't the 911 engine mount bar *hang* off the mounts, just like a 914 transmission ... (IMG:style_emoticons/default/confused24.gif) Andy OOpps...I guess you should not believe everything you read. |
Lo-Fi Version | Time is now: 14th March 2025 - 10:45 AM |
