Loud Klunk! Oh Nooooooooooo |
Curvie Roadlover |
Aug 22 2006, 11:18 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Hi Gang, long time no see. The other day I was driving alon (minding my own business). I was stopped at a red light. As I began to pull away after the light changed, I heard a loud clunk, and, while the engine kept running, there was no drive. As I coasted into a parking lot, I looked in my mirror to see if I had left anything in the road - no. Anyways, The car now sits in the garage awaiting repair. Where should I begin. A cursory look didn't reveal anything obviously wrong. (IMG:style_emoticons/default/sad.gif)
Thanks in advance for your replies |
fiid |
Aug 22 2006, 11:22 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Seems most likely to me that a CV joint has failed. If you start it up and pop it into gear while somone is looking (perhaps with eye protection) back there - It ought to be obvious that this is happenning. Don't do this for very long since you're only adding damaing to an NLA part.... Theres a crew on the board making new 914 CVs out of bug parts - so that would be the way to go for a replacement.
If it's not that then: Could also be that you're not getting into gear? Something gone in the transmission? Clutch problem potentially? |
DNHunt |
Aug 22 2006, 11:23 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
CV joint? I start by tugging on the axles
Dave |
TonyAKAVW |
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I had the same thing happen to me once before. I'm willing to bet the bolts from one of the CV joints on the transmission loosened up and the axle fell onto the exhaust. Engine will still run fine, transmission will shift but you won't go anywhere.
-Tony |
fiid |
Aug 22 2006, 11:24 AM
Oh yeah. Be really careful if you fire it up, have it in gear and are looking under the car. I think I'd put it on jack stands before doing that. and leave the handbrake on. Anything rotating = dangerous to fingers, eyes, groins, hair, loose clothing... caveat emptor. Be safe first. And don't run yourself over.
GWN7 |
Aug 22 2006, 11:39 AM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Hi Tom,
LTNS What they said ...check the CV's |
ptravnic |
Aug 22 2006, 11:42 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Definitely CV joint. Move the axle back and forth w/the car in
neutral and jacked up (wheels dangling free). This happened to me a couple years back. The guys making the modified cv's are in the link below: http://www.914world.com/bbs2/index.php?show...mp;hl=cv++joint |
Curvie Roadlover |
Aug 22 2006, 11:43 AM
Hey Bruce, is it winter where you are yet?. I'll get it up on jack stands and have a look at the CV joints. Thanks for the immediate responses You guys rock. (IMG:style_emoticons/default/aktion035.gif)
Dr Evil |
Aug 22 2006, 11:49 AM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yes, CV or maybe a sheared roll pin in the linkage inside the tranny. Does it feel like is still shifts into gears?
Bartlett 914 |
Aug 22 2006, 12:00 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Looks like this has happened to a lot of us. I was in Battle Creek MI 2 months ago and the same thing happened. My CV joing had worked it's way off. All the bolts were still there they just loosened themselves and the joint fell off the transmission. It was a good thing this happened at a low speed! I was lucky. Just as I pushed into a parking lot. I person pulled up and handed me his business card. His name is Jerry at Euroeast Porsche shop. He was only 1 minute away! Turned a real bad into a pretty good one. If this is the case with your car, I reccomend using new lock washers and maybe some locktite on the threads. There also needs to be a gasket installed.
Mark |
Dr Evil |
Aug 22 2006, 12:08 PM
Or my special bolts that you can lock wire (IMG:style_emoticons/default/idea.gif)
Events like this is why I made them. |
bondo |
Aug 22 2006, 12:10 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Welcome back Curvie!
(I agree with the others.. CV problem) |
STL914 |
Aug 22 2006, 01:40 PM
Senior Member Group: Members Posts: 1,183 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Same thing happened to me last year about a mile from home. Parts cars are a blessed thing to have around. Off with the old on with the new.
Eric_Shea |
Aug 22 2006, 01:55 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We missed you Tom. Update on all things Michy? How's your buddy... was it Bob?
We're working on a new CV solution. I just sent the kits to Mr. Mueller for a little re-working. Mr. Evil will also play into this as we have had quite a bit of interest in a Pro CV kit. Stay tuned. |
Curvie Roadlover |
Aug 22 2006, 02:32 PM
Hi Eric, All's well in MI, except that my car isn't running. Hopefully it's the CV's like everyone seems to think. I don't want to tear into the gearbox if I can avoid it. How's things in UT? Bob's good - Got married in February so he didn't attent the annual ski trip this year, which, by the way, was to Whistler, in BC. - awesome.
Headed to Lake Louise, in Alberta for 2007. I'll put up a post when I get home from work and can take a look at the CV's.. Thanks, again, everyone for the fast replies (IMG:style_emoticons/default/smiley_notworthy.gif) |
Curvie Roadlover |
Aug 22 2006, 03:45 PM
5 of the 8 CV bolts were loose, 3 on the drivers side and 2 on the pass. side. The drivers side CV appears to be toast. Took it off the tranny and it rained down bits of metal and ball bearings (IMG:style_emoticons/default/sad.gif) I guess the good news is I now know what happened and I'm not gonna need to drop the motor to fix it (right?? (IMG:style_emoticons/default/confused24.gif) )
TonyAKAVW |
Aug 22 2006, 03:52 PM
That'll do it. No engine drop needed.
-Tony |
So.Cal.914 |
Aug 22 2006, 03:53 PM
No.
davep |
914 Historian Group: Benefactors Posts: 5,220 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You may have to drop the heat exchangers. Same thing happend to a friend. His left inboard CV fell off the tranny and whacked the gearshift rod. Good thing it did not hit the starter. After I towed the car to my place I found the one rear caliper piston had worn right through the backing plate and was wearing on the rotor.
Gint |
Aug 22 2006, 05:23 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Watchyagotthere is some bad 914 Karma after leaving us alone for so long.
(IMG:style_emoticons/default/biggrin.gif) Get 'er fixed up and back on the road Tom. (IMG:style_emoticons/default/driving.gif) Good to hear from you again. |
Lo-Fi Version | Time is now: 27th December 2024 - 05:27 AM |
