> BLING! New 944/911 Axles, done and ready to be installed ...
post Aug 25 2006, 07:44 PM
Resident German
it's been a while since i started this project. i had all the parts, but i was waiting for the right time to redo the complete rear suspension ...
yesterday, i went up to McMark's and we took out the old trailing arms and axles and shocks and prepared my new trailing arms and the axles.
McMark finished the job today, and now i have:
- new (unbend) trailing arms
- new mueller roller bearings
- new koni adjustable shocks
- new axles with brand new 944 CVs
(IMG:style_emoticons/default/smilie_pokal.gif) Andy
PS: for the axles, i used, tranny to wheel:
915 (911, '75 - '79) coarse spline 6-bolt 100mm outputshafts ->
944 100mm CV ->
modified 914 axle shaft ->
944 100mm CV ->
911 ('75 - '79) 6-bolt 100mm stub axle ->
911 ('69 - '73?) hub
= real 5-lug!
on top, the stock 914 axle, bottom, the new axle using 944 and 911 parts:
and installed:
Replies(1 - 19)
post Aug 25 2006, 08:08 PM
Resident German
the main benefits of doing this, IMHO:
- 944 CVs are still readily available brand new for reasonable prices.
- 944 CVs are slightly bigger and wider than stock 914 CVs.
- real 5-lug hubs instead of redrilled 914 hubs.
(IMG:style_emoticons/default/smile.gif) Andy
pek771
post Aug 25 2006, 08:15 PM
Nice work, Andy!
What did the mods to the axle shaft consist of?
Pat
Aaron Cox
post Aug 25 2006, 08:26 PM
Professional Lawn Dart
not andy,
but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc
Chris Pincetich
B-)
(IMG:style_emoticons/default/drooley.gif)
I think you will see the yellow through your wheels.
sweet.
Looks pretty fast on those jackstands! (IMG:style_emoticons/default/beerchug.gif)
McMark
post Aug 25 2006, 09:03 PM
914 Freak!
QUOTE(Aaron Cox @ Aug 25 2006, 07:26 PM) *
not andy,
Nope. The 944 CVs are wider, so they need more room on the axle splines.
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg)
Aaron Cox
post Aug 25 2006, 09:04 PM
QUOTE(McMark @ Aug 25 2006, 08:03 PM) *
not andy,
ahh yeah. i lied. LOL.
that makes it mo betta
fiid
post Aug 25 2006, 09:20 PM
Turbo Megasquirted Subaru Member
OMG. That's delicious.
John
member? what's a member?
That is exactly what I did to 914-6 axle shafts to make 911 CV joints fit on them
Eddie914
post Aug 25 2006, 09:29 PM
Unregistered
What model and year did the stub axle and outputshafts come from?
Where is the 100mm measured on the stub axle?
I have one large four bolt stub axle and one six bolt. Not sure or the origin.
The outputshafts I have are from an '86 915 and are also four bolt.
Thanks
Eddie
post Aug 25 2006, 09:44 PM
Resident German
QUOTE(Eddie914 @ Aug 25 2006, 08:29 PM) *
915 output flanges and 911 stub axle came from a mid to late '70s 911 (~'75 - '79) and the hubs came from a early 911 (~'69 - '73?) ...
100mm is the dia. of the CV, so the flages and stubbies fit a 100mm CV ...
PS: and yes, stubbies and flanges and CV's are all 6-bolt ...
jonwatts
post Aug 25 2006, 09:45 PM
no rules, just wrong
Andy, your avatar looks weird. Did you have some work done?
Oh, and cool suspension stuffs.
post Aug 25 2006, 09:49 PM
Resident German
QUOTE(jonwatts @ Aug 25 2006, 08:45 PM) *
yeah, i spent about an hour in front of two mirrors with a clipper and razor blades trying to get the hawk straight and centered ... (IMG:style_emoticons/default/biggrin.gif)
not perfect but gud enough for me ...
(IMG:style_emoticons/default/aktion035.gif) Andy
Mueller
post Aug 26 2006, 12:43 AM
914 Freak!
QUOTE(SirAndy @ Aug 25 2006, 06:44 PM) *
915(911) coarse spline 6-bolt 100mm outputshafts ->
944 100mm CV ->
you're welcome (IMG:style_emoticons/default/smile.gif)
944 100mm CV ->
911 6-bolt 100mm stub axle ->
911 hub (real 5-lug!)
and installed:
If you decide to sell those other parts, I think those spacers I made for you will need to be trimmed down a bit hieght wise....
So.Cal.914
post Aug 26 2006, 12:48 AM
"...And it has a front trunk too."
Kind of look like Sting when he was young, like in Quadraphenia, but without the
mohawk.
I like the upgrades, looks bada$$.
McMark
post Aug 26 2006, 01:08 AM
914 Freak!
Actually, Mike they were about 0.25mm too short. Completely usable (IMHO), but visibly short. Not your fault, mostly Andy's. We need to buy that guy a digital caliper. (IMG:style_emoticons/default/smile.gif)
barrym
post Aug 16 2016, 02:34 AM
dragging up the old posts here ... which 944 cv joint did you use ? 944 s2 turbo ? are they all the same ?
thanks
post Aug 16 2016, 03:01 AM
Resident German
QUOTE(barrym @ Aug 16 2016, 01:34 AM) *
No turbo, just yer plain old 944 ...
Cracker
post Aug 16 2016, 06:22 AM
Very nice Andy. Have you had a failure in the past or was this a proactive move on your part?
Tony
post Aug 16 2016, 12:02 PM
Resident German
QUOTE(Reverend Troublemaker @ Aug 16 2016, 05:22 AM) *
I wanted real 5-lug in the rear, not re-drilled hubs.
The slightly larger CVs were an added bonus.
- Lo-Fi Version Time is now: 20th April 2025 - 12:39 PM
