jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
I've got a '76 2.0 and I'm having problems with the connection to the pressure sensor. The harness side of the connector has four female contacts in a white plastic housing, and one of the contacts won't stay put - it just slips out and comes loose, causing a No Start/No Run condition. Had to coast over to the side of the road while heading down Ute Pass yesterday to press it back in. Q : Is this a standard connector ? Q : Anybody know who sells it ? Q: Anybody ever try to epoxy something like this into place ? (I'm worried that it's be to hard to get really clean...) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
DO NOT EPOXY! If you do, you'll never ever ever get it out of there again...
The metal contact is a 3mm barbed female spade connector. I believe that one of the Wurth assortments has these in it, so talk to your local Porsche mechanic (if you have any local that is!) and see if he'll dig one out and sell it to you. You'll need to crimp it on with a quality crimper, so it might be easier just to talk to the mechanic and have him do the whole replacement. Who knows, he might be willing to do it for a beer? Versions of those connectors were also available through Beck-Arnley at one point. They were 1/8" instead of 3mm, so they did not fit perfectly but they did fit. Someone also posted a link to a Volvo parts place that carries at least some D-jet parts; they may have the metal connectors too. --DD |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
BA still carries those parts.
If you want, I can pull one off of a junk harness and ship it out to you. just pm me your addy and i'll get it out when I have time (very busy lately (IMG:style_emoticons/default/sad.gif) ) b |
Lo-Fi Version | Time is now: 26th June 2024 - 05:14 AM |
