> Wiper Switch, How is it removed?
jnp914
post Oct 28 2003, 11:33 AM
I have problems with the wiper system on the '71.
-When the ignition power is on, I cannot get the wipers to move. In the full left position, I can wiggle the knob and I hear slight movement up around the motor, but I get nothing in either the middle (slow?) or right position.
-The Haynes manual says that I should pull out the knob to the first position for low and all the way out for high. Nope, the switch in the car is a rotary, three position. Which one is correct.
-How do I get the switch out of the dash? I removed the dash bottom, but see no obvious access to remove the switch.
TIA
Replies(1 - 4)
post Oct 28 2003, 12:55 PM
Resident German
mine was rotary style too (before i switched to a late model harness) ...
removal is easy. first rotate the knob to the left, the top should unsrew!
then you see a metallic (alloy i think) ring with 2 slots in it.
now comes the tricky part. and i don't recall if there's still a stud sticking out once the knob is removed, but
IF NOT: just use a quarter (yes, money), it'll fit perfectly into the 2 slots and unscrew the metal ring. then the whole switch just slides out the back.
IF YES: you won't be able to get a quarter in there, so use a flat screw driver and carefullt pry counter clockwise. once the ring is off the whole switch just slides out the back.
Andy
si2t3m
post Oct 28 2003, 02:34 PM
914 addict
I'll try to think about posting a picture of the switch tonight. You will see how to take it out of the dash.
I'm modifying mine. I'm adding a microswitch so that the middle part will activate a windshield washer pump.
Marc-André
jnp914
post Oct 28 2003, 03:21 PM
Just grab it and twist to the left?
Sounds like one of my earliest college dating techniques.
post Oct 28 2003, 03:22 PM
Resident German
QUOTE(jnp914 @ Oct 28 2003, 01:21 PM)
yes on both (IMG:style_emoticons/default/laugh.gif)
- Lo-Fi Version Time is now: 4th January 2025 - 07:22 PM
