> Center Console: Measurements?, for the DIY builder
Brian Mifsud
post Sep 24 2006, 08:09 PM
Mechanical Engineer
(IMG:style_emoticons/default/sawzall-smiley.gif) Has anyone measured and made up a drawing of the center console? I'm a pretty decent woodworker and one for my '76 which was never equipped. I'd like also to toss that crappy plastic chunk of foam.. the quasi-armrest, so thought I'd integrate it with the OEM style center console.
Thanks
Replies(1 - 19)
eg914
post Sep 24 2006, 11:09 PM
I have a link to a french 914 site, but it no longer works. The main site seems to be fine.
http://914france.ifrance.com/914france/console.htm
There were 10 gif files with dimensions in mm. I hope I have attached them.
Attached ImageAttached ImageAttached Image
I wish that I had the authors name, to give credit where due. It may be that the link above is only temporarily out of order. Good luck
Dave_Darling
post Sep 25 2006, 08:10 AM
914 Idiot
Bill, thanks for saving those measurements!!
--DD
Brian Mifsud
Mechanical Engineer
(IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif) Tremendous!!! (IMG:style_emoticons/default/clap56.gif)
Brian Mifsud
post Sep 25 2006, 08:41 AM
Mechanical Engineer
Does anyone know what the angle is for the side panels, as described by lines ED to DC? (on drawings "Figure #1 and Figure #2) I can figure out the rest by measuring the actual space inside the car, but with now real console to use as a pattern, I'd just be guessing otherwise.
Thanks
Matt Meyer
post Sep 25 2006, 09:10 AM
Überlurker
It is about 105 degrees.
I have a cad drawing made from the website if you want it and can open AutoCAD .dwg files.
Brian Mifsud
post Sep 25 2006, 10:30 AM
Mechanical Engineer
QUOTE(Matt Meyer @ Sep 25 2006, 08:10 AM) *
That would be a great time saver. thanks Matt
Always Looking
post Sep 25 2006, 10:52 AM
Great info. What wood are you, Brian, going to use. I was thinking of mocking one up in cardboard today.
Dan
BarberDave
post Sep 25 2006, 11:39 AM
Barberdave
Brian: I have some old console sides ,that arn't any good to me. laying around
pay just shipping and you can have the orginials to work from. The place ment of the kick back on the drivers side is important ,or your foot gets in the way of everthing. Let me know. Dave (IMG:style_emoticons/default/slap.gif)
t collins
post Sep 16 2007, 09:25 AM
QUOTE(Matt Meyer @ Sep 25 2006, 07:10 AM) *
PM sent
Thanks,
Tom
Plaindaner
post Sep 16 2007, 09:43 AM
Plaindaner
QUOTE(BarberDave @ Sep 25 2006, 12:39 PM) *
(IMG:style_emoticons/default/agree.gif) I just had my console out last week to install a pair of 5-1/4" mid-bass woofers. I was concerned about foot room as well. Ends up that the console cluster is shallow enough that I placed the woofers right up front, far away from my foot access. Oh, and they are soooo sweet!
McMark
post Sep 17 2007, 02:54 AM
914 Freak!
One of the measurements on the French drawing is WRONG... (IMG:style_emoticons/default/sad.gif)
but I don't remember which one. (IMG:style_emoticons/default/pinch.gif)
Brian Mifsud
post Sep 17 2007, 10:51 AM
Mechanical Engineer
QUOTE(McMark @ Sep 17 2007, 01:54 AM) *
One thing I CAN contribute to this forum is a good set of drawings. I have a good original console now. I'll measure it and then compare it to the French drawing.
Between the two, I will make up a new set that are accurate and post them here for all to use.
Brian Mifsud
post Sep 17 2007, 11:03 AM
Mechanical Engineer
QUOTE(Always Looking @ Sep 25 2006, 09:52 AM) *
Dan
Hi Dan,
The "5mm Exterior Hardwood" ply found at Home Depot is tempting, but I wouldn't recommend it. I did the "boil test" on it to see if it was worthwhile for marine applications (good marine or exterior grade ply will withstand being boiled indefinitely). The sample fell apart in one hour.
No the 914 isn't a marine application... BUT, the temperature swings inside a car a very brutal. Add a little humidity swing, and your console will probably start warping after the first summer.
"First Class" is some marine ply made from "Okuome" or "Meranti". You can find it in 3mm, 4mm, 5mm, 6mm, etc thicknesses. Pricey starting at $30/40 sheet for thin stuff.. but it is very stable and won't move on you. Perhaps, while you are in there, you can build some really nice new door panels too?
"Second Best" is MDO (Medium Density OVERLAY) plywood. Used for signmaking (NOT MDF Medium Density Fiberboard). I belive 1/4" is a thin as you can buy it, but it is also dimensionally stable, water and weather proof, and more readily available all over the country.
If you "must" go "cheap" using the Home Depot stuff.. make sure you seal it really well with some polyurethane after you've completed the last cut. Don't let the moisture migrate in or out (epoxy is best.. but the cost of using that negates the "savings" of using cheap plywood).
dr914@autoatlanta.com
post Sep 17 2007, 11:46 AM
We had made some big slabs of metal years ago that we use to precisely cut the consoles to the original dimensions. They work great! We also make the metals to bolt it all together.
roadster fan
post Nov 27 2007, 01:11 AM
Project Frankenstein !!!!!!!!
I was reading thru this thread after seeing Beamer13's console he built. I noticed that McMark said one of the measurements is incorrect on the french drawing. I believe it is the one circled in the pic below. I think it is 280mm not 380 mm as listed but I will have to duplicate the drawing in CAD to verify or do a little math i guess.
Hope this helps, if I find out for sure what that measurement is, I will let everyone know.
Jim
johannes
post Nov 27 2007, 02:31 AM
Club Porsche 914 France President
Region Association: France
Theese drawings came from the old french club' website.
I am in charge of the new site and have saved and moved the drawings on our new forum.
you can find them here
http://porsche914.fr-bb.com/articles-techn...entrale-t15.htm
(IMG:style_emoticons/default/welder.gif)
Beamer13
post Nov 27 2007, 02:40 AM
I don't suppose by some chance, you might have a copy of this translated into English?? I know, I know... I'm bein lazy :-) What do I need to read it for anyway? Right??? :-)
Rick_Eberle
post Nov 27 2007, 05:23 PM
QUOTE(Beamer13 @ Nov 27 2007, 07:40 PM) *
Try this thread...
zymurgist
post Nov 27 2007, 05:36 PM
"Ace" Mechanic
Dr Evil has a cool (non-OEM) console.
- Lo-Fi Version Time is now: 4th January 2025 - 11:15 PM
