JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,889 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The vacuum hose layout diagrams floating around did not reflect my late 1974 engine bay because the fuel vapor filter is mounted to the rear wall of the engine bay (different from early 1974 and before where it is on the fuel tank). So I made my own updated diagram. Everything correct as far as I know in cluding the nipple sizes and original hose colors, please let me know if you find any errors. Diagram and keynotes are below use them if you want.
The later cars have the fuel vapor filter in the engine bay too, but its bolted to the battery tray clamp. Conceptually, is that arrangement plumbed any differently? Attached thumbnail(s) ![]() Attached image(s) ![]() |
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
Jeff,
where did you get that chart with hose lengths or did you make that also |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,146 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Jeff, could we have permission to post a copy on the Bird site?
--DD |
JeffBowlsby |
I made the chart of lengths and colors by measuring the hoses from my original 74 Bumblebee and comparing photos of several original 914 2.0Ls from late 74.
Dave...absolutely. |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Very nice Jeff!! (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif)
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Jeff, hose #10 for advance, is it connected or simply plugged on your diagram. Also, anyone knows where to find those elbows and especialy that double outlet rubber piece for the decel valve and PCV valve? Edit: Oh yes, it should be added to the classics. |
Lo-Fi Version | Time is now: 19th April 2025 - 08:15 AM |
