Could this be the problem... I'm reaching here I know, FI harness... who knows where I can get one |
tdgray |
Nov 4 2006, 03:05 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Well I am completley stumped.
Those of you who have followed my various threads on my car fouling plugs like crazy know all the things I have replaced etc. I went out to the garage today to try to see if I could find SOMETHING... anything that seemed out of place. As I was fiddling with the connectors for the Fuel injectors I heard minor changes in the way it was idling as I was bending wires. Could my FI harness be to blame for my fouling? One other thing I noticed was that when in acceleration (read not idling) the rich smell was less noticable and the smoke when I let off the throttle was not black.... was actually white in a few cases. I know I am reaching but I just cannot figure out where to go from here. Geoff (bleyseng) if you read this... I think I am going to send my MPS back to you for a check. I just don't know what else to do at this point. |
Aaron Cox |
Nov 4 2006, 03:13 PM
B O W L S B Y harnesses...
bd1308 |
Nov 4 2006, 03:17 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
Bowsby harness + MPS check. Once those boots are gone, the rest is soon to follow, and then you get all kinds of crazy problems
Ive seen Jeff Bowlsby's harnesses, they are FiNe (IMG:style_emoticons/default/wub.gif) |
tdgray |
Nov 4 2006, 03:19 PM
Got it thanks boys...
double a... aren't you supposed to be in seclusion (IMG:style_emoticons/default/biggrin.gif) |
BarberDave |
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Sounds to me like a new F.I. harness is needed. After 30 yrs. electrical conectors harden. Imagine what thirty yrs. of heat can do. Member here Jeff Bowlsby makes the best . Dave (IMG:style_emoticons/default/slap.gif) |
type47 |
Nov 4 2006, 05:33 PM
you could disconnect the wiring plug at the ECU and test all wires for continuity to see if there are any faults.
robby750 |
Nov 4 2006, 06:11 PM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
If you can change the way the engine runs by moving wires, then I can assure you the harness is toast. Who knows what all in the system is affected with poor connections? I replaced mine with a Bowsby harness and cured all kinds of intermittant problems. They are expensive but it was well worth it.
solex |
Nov 4 2006, 10:21 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I fourth the motion for a bowlsby-harness.
I had similar problems with my 75 eventually I tried to remove a connector at the distributor and the wires eventually came apart at the connector. You won't regret the investment, my car runs so much better with the new harness and Jeff is a stand-up guy. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:32 PM |
