Slowpoke |
Member ![]() ![]() Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 ![]() |
I permanately removed the relay board on my wire harness, (whole wire harness is on my living room floor) I'm looking at a picture of a relay board to determine if I have my voltage regulator wired right. I have the stock wire harness comming from the alternator plugging into the voltage regulator, on the D+ or red wire going to the voltage regulator I crimped on the blue wire from the generator light. Is this right?? I don't see what is exciting the alternator, to get it to charge. Too much GM wrenching time! I know the gen lite is important to the charging system but does it excite the alternator?? I'm pretty close to tearing apart a good relay board to check this out. (IMG:style_emoticons/default/confused24.gif) Which I guess there is no shortage of anyway, but just seems like a waste. I'm sure someone has done something like this before.
Thanks Peter |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
What are you using for a relay to turn the fuel pump on ??
B |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
You've got the VR wiring right. As for what kick-starts the charging field, it's the "idiot light" bulb.
http://www.pelicanparts.com/techarticles/9...roubleshoot.htm --DD |
Slowpoke |
I used one of the original four red power wires from the battery to power a new relay. I'm using the rear defog switch on the dash to turn on the relay for the fuel pump. It's a carbed car. I guess it will be kind of an anti-theft for morons kind of deal. (IMG:style_emoticons/default/cool.gif) But mainly, I just like an independent method of controlling the electric fuel pump and I don't want to have any out of place looking switches on the dash. I think it would be easier if the harness was in the car. It is more diffecult when it's in the house and I have to keep what is powering what, straight in my head.
Peter |
Lo-Fi Version | Time is now: 26th June 2024 - 02:55 AM |
