bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
I'm rebuilding some webers for markb, and the holes in the tabs on the body for receiving the screws that hold the top on are cracked, and one is actually half missing (only half the hole is there). Is there any chance of welding this stuff or should I just do what I can with JB weld?
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,625 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I'm rebuilding some webers for markb, and the holes in the tabs on the body for receiving the screws that hold the top on are cracked, and one is actually half missing (only half the hole is there). Is there any chance of welding this stuff or should I just do what I can with JB weld? The 40's on my six have an epoxy repair... |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Marine-tex is your friend
bondo |
Hmm, that's kinda what I figured. Is that really the best way to fix it? I guess I should be glad it's not spot exposed to gas.
Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
I'm rebuilding some webers for markb, and the holes in the tabs on the body for receiving the screws that hold the top on are cracked, and one is actually half missing (only half the hole is there). Is there any chance of welding this stuff or should I just do what I can with JB weld? They can be welded very easily, by a good welder, the problem then is getting the weld machined flat, so no leaks, then the holes re drilled and tapped straight. I just had 2 sets done, and 1 of them for the same reason as yours, actually worse, 3 corners were broke off and the 4th was cracked. |
bondo |
I'm rebuilding some webers for markb, and the holes in the tabs on the body for receiving the screws that hold the top on are cracked, and one is actually half missing (only half the hole is there). Is there any chance of welding this stuff or should I just do what I can with JB weld? They can be welded very easily, by a good welder, the problem then is getting the weld machined flat, so no leaks, then the holes re drilled and tapped straight. I just had 2 sets done, and 1 of them for the same reason as yours, actually worse, 3 corners were broke off and the 4th was cracked. Ooh, that's what I wanted to hear. Anyone have any junk weber parts I can practice on? (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 11:32 PM |
