m_davidson |
Newbie ![]() Group: Members Posts: 37 Joined: 20-November 05 From: Bellingham WA Member No.: 5,156 ![]() |
I will be converting my rear wheels to 5-bolt as part of a 914-6 conversion. I have a set of early 4-bolt hubs redrilled to the 5-lug pattern. Will the early 911/912 rear solid disks fit these hubs with stock calipers?
I notice the Performance part numbers for the 914-6 vented disks are the same as for the early 911 vented disks. The early 911 solid disk diameter and thickness seem to be about the same as for the 4-bolt disks. I realize the inner 911 hand-brake surface will not be used with the 914 hand-brake. Mel |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
They work fine!
Some of the rear calipers are not all created equal so I test fit the rotors with the caliper torqued down over it. Spin it without pads in the caliper and make sure it is not rubbing on the caliper. I have seen some calipers that are twisted on their assembly through bolts. The concern: rotor growth under pro-longed use. The rotors will grow several MM's in some cases depending on what brake pad you use and how hard you are on the brakes. Bottom line: check the clearance and clearance the calipers if needed. B |
m_davidson |
Thanks Brad,
One advantage of the early 911 disks is that they seem readily available new for a reasonable price. I suppose if there isn't enough clearance, I could always have them machined down. Mel |
Lo-Fi Version | Time is now: 26th June 2024 - 04:12 AM |
