> Bought a CHT Gauge, FINALLY
McMark
post Nov 23 2006, 01:34 AM
914 Freak!
I finally invested in a CHT gauge. This is the one I got.
(IMG:http://www.aircraftspruce.com/catalog/inpages/inmisc/CH130.jpg)
I wanted to get a temperature compensating model. VDO CHT gauges read high or low depending on the ambient temperature in the cabin. And as a bonus, this model is about $15 cheaper than the VDO. (IMG:style_emoticons/default/wink.gif)
It should be here Saturday, and then I get to install it. It will be interesting to see what my head temps are running at with 9.5:1 compression.
I wanted to get a baseline of CHT and oil temps before I pull the motor and upgrade the cam.
Replies(1 - 7)
Hammy
post Nov 23 2006, 02:12 AM
mr. Wonderful
Looks cool Mark.
I like the temperature compensation
I've been meaning to get a CHT gauge for myself.
Do you know if it comes with the sender and wires?
McMark
post Nov 23 2006, 05:25 AM
914 Freak!
You can buy them on the same site. Click on Instruments and the Probes & Senders. You need the 14mm setup. I can get you part numbers if you need them.
bd1308
post Nov 23 2006, 08:27 AM
Sir Post-a-lot
I bought one from Dakota Digital. I like it, it compensates too.
Nice job though, there's something about analog gauges...
Demick
post Nov 23 2006, 10:28 AM
Ernie made me do it!
Gotta laugh at the description. They advertise 2% accuracy, but you can only read the gauge to about the nearest 25 degrees.
PinetreePorsche
post Nov 23 2006, 10:51 AM
So where does this one read the temp, and what do you have to do to install the sensor land lead? -Chris H.
McMark
post Nov 23 2006, 12:25 PM
914 Freak!
The thermocouple (sender) goes under the #3 spark plug. Just unscrew the plug, slip the thermocouple around it like a washer, and then screw it back in. Route the wire through the factory harness and to the gauge. No problem. I'll take pictures when I install mine, should take about an hour.
PinetreePorsche
post Nov 24 2006, 07:05 AM
OK--even went to the spruce link and looked at it. Still don't know: what does 1-2-3 and 2-4-6 refer to? Hundreds of degrees? Why not 180 to 34o, spread across the dial? Why am I clueless? -Chris H
- Lo-Fi Version Time is now: 27th November 2024 - 07:00 AM
