Front shift rod |
Front shift rod |
jeffdon |
Nov 25 2006, 05:13 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Hey, whats the trick for taking out the front (shifter to firewall) shift rod? Trying to replace all the bushings. All i can think is that i have to take the cup off the end and slide it out of the tunnel towards the rear of the car, but hopefully someone has a neater trick.
Mueller |
Nov 25 2006, 05:22 PM
it's been awhile since I've dealt with that part, but I want to say that you can just loosen the shifter and move the rod towards the front of the car to gain access to the bushing.
either that or loosen the rod at the shifter and move the rod forward... |
GeorgeRud |
Nov 25 2006, 05:49 PM
Depends if you have the early or late style shifter. Unbolting and lifting the shift tower up will release the early style shiftrod, the later ones have the rod bolted to the end of the shifter. Either way though, you have to unbolt things and pull it back through the firewall if you want to replace all the bushings (which is the whole idea anyway).
jeffdon |
Nov 25 2006, 05:56 PM
Depends if you have the early or late style shifter. Unbolting and lifting the shift tower up will release the early style shiftrod, the later ones have the rod bolted to the end of the shifter. Either way though, you have to unbolt things and pull it back through the firewall if you want to replace all the bushings (which is the whole idea anyway). Kinda what i thought. Its a tail shifter, by the way. Thanks for the help! |
Lo-Fi Version | Time is now: 20th June 2024 - 05:49 AM |
