> Oil system for track car, Dry sump tank location
MikeSpraggi
post Dec 6 2006, 09:37 AM
I will be installing a fuel cell in the front trunk of a teener that I will be using primarily for DE and later some club or historic racing.
Since I will be removing the original gas tank and have some space to work with, has anyone seen a dry sump tank located in that area where the factory gas tank is located?
Replies(1 - 11)
TravisNeff
post Dec 6 2006, 10:14 AM
I have seen a few cars with a peterson style oil tank up where the gas tank used to be - on the passenger side. Don't have any pics of it though.
jd74914
post Dec 6 2006, 01:44 PM
Its alive
Hi Mike, Chris Foley might have a dry sump tank in the old gas tank area. I'm not positive that his is there. btu I remember seeing it in an odd place.
brant
post Dec 6 2006, 01:49 PM
I've seen many cars set up this way.
in fact, often if a round (peterson style) oil tank is used then the firewall into the passenger compartment is cut and welded back with a re-shape to allow the round tank to sit lower.
brant
MikeSpraggi
post Dec 6 2006, 03:18 PM
Thanks guys ........ just wanted to make sure I wasn't out in left field with wanting to mount a tank there. Now, need to figure out all of the particulars .... pumps, plumbing etc. Thanks again.
jeff
post Dec 6 2006, 04:34 PM
Check out patrickmotorsports.com they have pictures in their gallery of the front mounted tanks on some beautiful race cars,good luck! (IMG:style_emoticons/default/welder.gif)
Mueller
post Dec 6 2006, 04:39 PM
914 Freak!
QUOTE(MikeSpraggi @ Dec 6 2006, 07:37 AM) *
Before doing the fuel cell, you might want to read ALL of the rule books from the orgs you are interested in running with..it would be a shame to build the car for the class that has the least amount of restrictions and be left out in the cold with the other clubs/orgs
john rogers
post Dec 6 2006, 05:44 PM
You did not mention what engine, but if it is a four the tank can go where the batt used to sit if it is moved to the rear trunk which many racers do. If you have a six conversion in the future, there is the possibility of mounting the oil tank in the rear trunk as I did which gives a very short run from the tank to the oil pump suction.
jd74914
post Dec 6 2006, 05:51 PM
Its alive
Mike, is this for the blue 2.7 you had?
MikeSpraggi
post Dec 7 2006, 08:25 AM
I have a 2.2L six, mostly "S" specs except with Solex cams, I will be putting this in a 1970, flared, 5 bolt conversion 1.7 I bought in Philly for $700 ... and it runs!
The blue '74 will be sold by this weekend. I'm only waiting for the title to arrive from the owner in Colorado so I can hand it over to the new owner .... sigh .... I REALLY wanted that car .....
Series9
post Dec 7 2006, 11:36 AM
Lesbians taste like chicken.
Mine:
jd74914
post Dec 7 2006, 10:13 PM
Its alive
QUOTE(MikeSpraggi @ Dec 7 2006, 09:25 AM) *
Not bad . . . the blue car was very nice tho
- Lo-Fi Version Time is now: 26th December 2024 - 01:17 PM
