Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I finally got the interior out and removed the rocker panels and bumpers. Here's what I found:
The right side: Attached image(s) ![]() ![]() |
Cevan |
Here's the left side:
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
I've seen people here repair far worse.....good example of why you should clean behind the rocker covers....how's the hell hole?
Cevan |
I've seen people here repair far worse.....good example of why you should clean behind the rocker covers....how's the hell hole? I haven't started to clean the engine compartment yet. The battery tray is rusted but the support for it seems fine. I've poked around underneath the supprt and couldn't find any major problems. The metal behind the rockers is called the inner rocker or the logitudinal? |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
The metal behind the rockers is called the inner rocker or the longitudinal? that is called the inner rocker which makes up the clam shell that makes the longitudinal. Shop here |
Cevan |
Well, after a little help from EJM (ok, alot of help), I actually got my car running tonight. I now own a running 914. (IMG:style_emoticons/default/beerchug.gif)
So now I'm thinking, I'd really like to take it out of the garage and drive it up and down my driveway, which is about 1/4 mile long. The only problem is that my headlamps are burnt out and it's dark out, windy and cold, and I have no doors or top on. No problem. I grabbed my HID headlamp mounted to by mountain bike helmet, started the engine and eased it into 1st. Tested the brakes and they appear to work ok. Continued down the driveway. 2nd gear no problem. Reverse works too. I've reached a milestone. (IMG:style_emoticons/default/driving.gif) Now it's on to phase 2: rust repair (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) More pictures to come. This is what I'm shooting for: Attached image(s) ![]() |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Bithchin looking car with a perfect stance.....
Good Show...!!!!!!!! C |
PinetreePorsche |
Member ![]() ![]() Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 ![]() |
Is it permitted to ask what the car cost? And is the motor, which runs up the driveway, in better shape than the body? Just want to know what others have bought in to--I'll have some rust work to deal with on one of mine when the motor is swapped out.
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
OK! Long weekends coming up. I'd say you will be pretty buisy if your gonna be through by Tuesday....
ejm |
So now I'm thinking, I'd really like to take it out of the garage and drive it up and down my driveway, which is about 1/4 mile long. The only problem is that my headlamps are burnt out and it's dark out, windy and cold, and I have no doors or top on. No problem. I grabbed my HID headlamp mounted to by mountain bike helmet, started the engine and eased it into 1st. Tested the brakes and they appear to work ok. Continued down the driveway. 2nd gear no problem. Reverse works too. I've reached a milestone (IMG:style_emoticons/default/smilie_pokal.gif) that engine sounded good when it fired up briefly Saturday... had a bad duel relay, bad points and I suspect some stuck injectors.... the rust is mostly where road crud gets trapped... floors and front trunk are nice... interior is decent... |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Well, after a little help from EJM (ok, alot of help), I actually got my car running tonight. I now own a running 914. (IMG:style_emoticons/default/beerchug.gif) So now I'm thinking, I'd really like to take it out of the garage and drive it up and down my driveway, which is about 1/4 mile long. The only problem is that my headlamps are burnt out and it's dark out, windy and cold, and I have no doors or top on. No problem. I grabbed my HID headlamp mounted to by mountain bike helmet, started the engine and eased it into 1st. Tested the brakes and they appear to work ok. Continued down the driveway. 2nd gear no problem. Reverse works too. I've reached a milestone. (IMG:style_emoticons/default/driving.gif) Now it's on to phase 2: rust repair (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) More pictures to come. This is what I'm shooting for: Cool. 914 life (IMG:style_emoticons/default/biggrin.gif) Welcome to: Pain, misery, anger, confusion, hell, empty wallet but most important of all..... happiness (IMG:style_emoticons/default/smile.gif) |
Cevan |
I paid $150 for the car. The guy wanted his son to restore it, but he wasn't interested. The rust repair required doesn't look too bad (for a 914), dfinately doable. There is no hellhole.
Question regarding inner rocker repair: Based on the slope of the sill, I assume I need to remove the sill in order to cut out the part of the inner rocker that is rusted. Am I correct? |
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Not bad at all!
Cevan |
Yes, original color, code L99. The paint is very faded so my wife called the color puke green. She's coming around though. It'll be repainted the same color, some day. |
Lo-Fi Version | Time is now: 29th June 2024 - 06:48 PM |
